Old 02-28-2012, 05:17 PM
Wayne -- I'd adjust the pinion angle UP 2 or 3* and see if that helps with the shock mount issue. You'll ultimately need to set this when the motor etc and with the car fully weighted... but this would at least let you see if that is going to be something of a cure.
I would ASSume you're motor is going to be set with a 3* down angle... and that would have the pinion angle "nose high" approximately the opposite 2 to 3*
Old 02-28-2012, 05:32 PM
Right now the car is up on jack stands so I don't think I can set it until its on the wheels? Correct?
Old 02-28-2012, 05:38 PM
Set the jackstands under the axle....
The axle will still roll on the stands so you can mess with it. If it's all nicely painted put some rags on the jackstands.
Old 02-29-2012, 07:22 AM
Nice work Wayne, keep it up. Your going to have a ride you can be proud of when done
Old 02-29-2012, 05:21 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Good luck Wayne. I hope you find a fix for this problem.
Old 03-04-2012, 08:43 PM
I did some work in the trunk. I painted the black/Aqua spatter paint, and touched up the sound deadening/under coat on the inside of the quarters. Here are some pictures.
This is a picture of the over spray inside the trunk.
Now with the touch up
And now with the spatter paint. It still has some light spots, one of the cans the paint didn't all come out.
I already ordered more paint from Eastwood to finish up. The the clear will go on.
When you paint something that is galvanized do you have to remove it before painting, or is there an adhesion promoter you can use. Its for the floor plugs.
Old 03-04-2012, 08:52 PM
Tuske427's Avatar
Tuske427 Tuske427 is online now
Lookin' good! I wish I was that far along
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 03-05-2012, 03:41 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
trunk looks real good Wayne and so does the rest of your work
Old 03-05-2012, 08:13 AM
War's Avatar
War War is offline
Nice work Wayne
Jason
Old 03-05-2012, 08:57 AM
g356gear's Avatar
g356gear g356gear is offline
Hey Wayne,
Just a heads up , the Eastwood clear is a very high gloss. It may not be what you are looking for. I was not overly happy with mine. I liked the semi flat look that it had before I cleared it.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
