Old 12-31-2011, 04:10 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
Did a few more things on the car, such as testing tire fitment. Looks like it will be fine on the rear, obviously too wide for the front but I threw it on there just to get an idea of height. 275/55/17, 28.91 diameter. Wish I had the rear fender skirt here, I can't remember how the latch worked or if it will interfere with the tire, I think it swung straight down but not sure.
What I do know is that a roadside tire change will be next to impossible as I need to drop the rear-end down to get the tire over the brakes. Going to have to think a bit on that one.
Brakes are just a dual 9in booster and disc brake master/proportioning valve. 3.5-1 pedal ratio. Boxed in the firewall area with 11 gauge steel.
Engine/trans are in place. I need to make motor mounts (and new trans crossmember) as I set the engine back 4.5inches from where RS put it. The engine and trans oil pans are 1.25 below the frame rail. Still a bit over an inch off the ground when the suspension is on the bump stops but I may raise up the front of the engine slightly to gain some clearance but I wanted to keep driveline angles shallow.
Old 01-17-2012, 08:57 PM
INTMD8's Avatar
Lincoln MK VIII fan fits just about perfect with a little shroud trimming and some aluminum brackets.
I would have considered buying something new but couldn't confirm that their is any other fan available that would outflow this one (and still fit in the available space).
Old 01-17-2012, 09:04 PM
INTMD8's Avatar
I decided to change to 4th gen F-body motor mounts and move the engine/trans back 5 inches. That required new motor mount plates off of the frame (will be boxed in on top). Steering shaft had to go through the motor mount plates.
All Borgeson pieces. Vibration reducing joint on the rack and telescopic shaft.
I'm going with a Wegner accessory drive similar to the pic below but with simpler windowed pulleys. I asked them to test fit an AD244 alternator because I will need a ton of amps and I was lucky enough that it fit perfectly with no mods to their brackets.
Tried the power steering pump and have good clearance between it and the rack.
Old 02-29-2012, 08:26 PM
INTMD8's Avatar
More pics. Decided on an LQ9 based 390ci motor with twin Tial/Garrett GT3076R's.
Fan didn't work out so I have something else on the way.
Old 02-29-2012, 08:45 PM
Love the car and definitely love the power!
Old 03-06-2012, 12:15 AM
INTMD8's Avatar
Thanks.
Oh look, some bling. I had the chrome shop send me this jigsaw puzzle and I assembled it so I could check for intercooler clearance.
Originally it was anodized and the face polished but I thought why not go with chrome to match the bumper.
Old 03-11-2012, 12:53 AM
INTMD8's Avatar
I worked on the car a bit more the last couple of days. I decided I didn't like my radiator mounting and intercooler placement. The radiator mounting just looked odd to me and the intercooler blocked off most of the radiator airflow.
I made some new brackets to mount the radiator from the backside, then made some mounts to bolt the fan shroud on and also new intercooler brackets. (so both intercooler and radiator get some direct airflow).
Also punched four holes through the core support. Two 3in stubs on top for turbo inlet and two 2.75 stubs down lower for charge side piping.
Old 03-11-2012, 08:56 AM
BanditDave BanditDave is offline
Looks amazing man...love your builds.
Did you ever sell the Malibu?
Old 03-11-2012, 11:29 PM
68 stang 68 stang is offline
Do you have all the stock cadillac parts you need? Or did you buy a complete car? If not I will put you in touch with the guy that we sold all our cad parts to. I love the car!
Old 03-18-2012, 07:58 PM
INTMD8's Avatar
Thanks! I sold the Malibu and another car to help finance this build.
In terms of stock parts I need a few small odds and ends but they are Brougham specific.
A bit more progress-
