Old 03-24-2006, 03:36 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Originally Posted by Twin_Turbo
Chris, I saw your pics over @ DC.. why did you decide to put the inner mounts where you put them? Are you aiming for the geometrical approach or the reduction of angularity??? (putting them centered and as close together as possible)?? If it's the 1st, look at the speed direct bracket, from the pics it looks as if they have it about right, yours looks to need the inner mounts moved 2" or so outboard.
Can you shoot a pic from the front where you can see both the upper and lower cross shafts as well as the rack bracket?
Are you talking looking straight down above the X member or from under the front looking back?
BTW--I intend to re-visit this once the car is up and running. There is no doubt this will work to hold it togethe and I can always rebuild the center bracket later and swap different tie rods. Without having the engine in I have been having to disconnect the front spring to get the A arms to swing into the natural drive position. I am ready to move onto the hydraboost now and hope to drop the engine back in there very soon. No more time budgeted to this right now.
I only have one dial indicator and setting up on one side of the rotor (with the spring and sway bar undone) moving the spindle up and down, so far it looks good. With the engine back in I can support on the control arm and bounce the car and check for bumpsteer movement.
Old 03-24-2006, 04:15 AM
Twin_Turbo Twin_Turbo is offline
No, looking at it from the front like the other 2 pics you took, but then hold the camera at ground level or so and aim it up so you can capture the rack, the lower control arm cross shaft and the upper 1 in the same shot. It should be possible. Doesn't matter if there's a bunch of stuff in the way, jsut so that these points can be seen and an evaluation of the geometry can be made (although crude)
It will work to hold it together but you will hate to drive the car with a lot of bumpsteer especially on rough roads.
Old 03-24-2006, 04:35 AM
Here's a crude chop of one of those pics you posted, the angle is a little weird to properly show it but it should be apparent why the inner tie rod mounts should be moved outboard. I'm not saying this to rain on your parade or soemthing but if you build it as close to perfect as you can now that will save you a lot of time when measuring bumpsteer with dial calipers, to be able to do that you already must be pretty close to where it should be. Otherwise you'll end up redoing it many times. The ideal tie rod length can easily be deter mined just by measuring under the car, err on the short side because there's plenty of adjustment in the tie rod ends (thread)
I know it's a rough sketch but this does show why the rod ends should be moved outboard, not take a look at the steeroids bracket. I can't tell exactly from the pics or measure it but it sure looks like they either have it correct or very close.
Old 04-25-2006, 07:03 AM
69MyWay's Avatar
Yipeeeeeeeeeee!
Got the car fired up this last weekend. The power steering is smooth as butter! The reaction is ultra quick and tight. I have driven it around the neighborhood about 2.5 miles or so and I love it.
As far as bump steer...tie rod relocation, etc...that is still on the drawing board. I have half a dozen other small items to get online INCLUDING getting the hydroboost working then I will re-work the details.
Old 03-24-2006, 11:38 AM
69MyWay's Avatar
Seeing what you have done on the photo-chop better helps me understand the other drawing.
One curious question I have though. How does the Grand Am work so well considering the geometry is out of line with the flow of the inner pivot point?
Fixing it this way won't be hard at all. It can easily be done with a larger bracket and custom tie rods.
Old 03-25-2006, 12:13 PM
What do you mean with this:
" How does the Grand Am work so well considering the geometry is out of line with the flow of the inner pivot point?"
The rack has nothing to do with the inner pivots, that's all done w/ the center bracket.
Old 03-25-2006, 03:10 PM
69MyWay's Avatar
The grand am does not have a bracket in the center. The grand am inner tie rod connects to the center of the rack. The lower control arm on the grand am is much shorter than a Vette (although the upper is handled with a strut).
My point being, it doesn't fit the model of the center line going up from the inner lower control arm bushings, etc.
Old 03-25-2006, 11:52 PM
Oh, that..yes the grand am attaches them to the center, where steeroids mounts their bracket. The grand am one works beause of the reduced angularity effect but why would you go that route if you can do a much better job? The grand am arms would require a really wide bracket on the rack, the vette w/ the long lower arms relativly close to each other gives you the opportunity to do it with a center plate to put the rods in the geometric right position and that way you have a real advantage over the other wya, which is only reasonable at best.
Old 03-26-2006, 02:12 AM
69MyWay's Avatar
Good info on the different designs Twin Turbo. One other difference is the knuckle for the tie rod to attach on the Grand Am is at the extreme top of the wheel area. Don't know what role that places in geometry of the syspension, but it is exactly opposite of the way it has to install on the Vette, since we have to put it very low on these cars.
I put the engine back in yesterday.
I now know better why I was able to connect with only two U-joints as it is clear my rack is lower than most. It is not a problem though because it is still higher than the low part of the oil pan.
I have more room than I thought to custom fit a different center bracket and tie rods. It really helps to have the engine it at this time to know where any interference items may be located.
Finished build the hydraboost yesterday as well and will be installing that soon. It will be easier to come back and tweak the tie rods after I get the car running again and can move it around a bit and then focus only on tweaking this aspect.
My list is shrinking, but I still have 100 other small things to do that are simply time consuming and minor detail in nature.
