Old 03-16-2012, 08:29 AM
I like the colored look when they first turn, but after a while they get pretty nasty looking, especially on turbo cars with the extreme heat. I ended up coating mine, looked MUCH better in my opinion, and cut some of the underhood heat.
Old 03-16-2012, 08:37 AM
Jay Hilliard's Avatar
John, If you engine is not broken in, do not break it in with new coated headers. I would go uncoated personally and coat later if you dont like the look.
Jay
Old 03-16-2012, 10:07 AM
parsonsj parsonsj is offline
Turbo heat is a whole 'nother animal. 321 stainless, and double top-secret coating for sure!
For N/A cars, the bronze natural look of 304 stainless is pleasing to my eye. What's cool is that the color slowly changes from the the exhaust port all the way to the tail pipe. The other thing about coated headers is that one little scratch ruins the whole look. They have to be sent out for re-coating. Natural stainless scratches can be rubbed out with some 3M red scotch-brite.
My Z06 headers are coated, and look good too, but are slowly losing luster. Of course, that motor stays near redline for 20 minutes at a time, so they see all the exhaust heat a normally aspirated motor can throw at it.
John Parsons
Old 03-16-2012, 11:37 AM
John510's Avatar
John510 John510 is offline
Engine is new. Thanks for the tip. I'll break in with uncoated and if the color bothers me later I can have them coated.
Thanks everyone for the replies. Much appreciated
[SIGPIC][/SIGPIC]
Old 03-16-2012, 12:10 PM
dubbleu's Avatar
dubbleu dubbleu is offline
If you can bolt on an old crappy set for engine break in that is best.
Old 03-16-2012, 11:01 PM
John510's Avatar
I don't have an old set? What does an engine do during break in that I don't want my headers on there?
[SIGPIC][/SIGPIC]
Old 03-16-2012, 11:08 PM
really not as much of an issue with modern LS stuff. Older engines with flat tappet cams required a 30-45 minute 2500 rpm run in when first fired to break-in the cam. The higher exhaust temps with the car sitting still (no real airflow) will dull the header coating in most cases.
New LS stuff or roller cam engines don't need that break-in, so if the tune is okay there's no heat issues.
Old 03-17-2012, 07:33 AM
69x22's Avatar
69x22 69x22 is offline
My stainless works headers uncoated still look good but the stainless Magnaflow exhaust system is rusting (cheap grade of stainless).
