Old 03-18-2012, 06:59 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
Old 03-18-2012, 08:20 PM
Rick D's Avatar
Rick D Rick D is offline
Looks awesome Jim How are the wheels coming?
Rick
Old 03-20-2012, 12:02 AM
INTMD8's Avatar
Still waiting on another cad drawing of the wheels.
Old 03-20-2012, 08:37 AM
strtcar strtcar is offline
Looks great
Old 03-20-2012, 10:01 AM
KPC67's Avatar
KPC67 KPC67 is offline
Great job!
Kevin Carter
Old 03-23-2012, 03:15 AM
66novass 66novass is offline
WOW TT ls engine in a 57 caddy on a RS frame... Didnīt see that one comming KING OF COOL
Old 03-23-2012, 07:58 AM
g356gear's Avatar
g356gear g356gear is offline
Very cool and unique build for sure! Where do you source your turbo exhaust manifolds?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 03-26-2012, 08:23 PM
INTMD8's Avatar
Thanks guys! The manifolds are flipped/modified and from a 2010 Camaro.
I almost finished up the cold side (just need to add bypass valves). The drivers side turbo piping runs under the engine and Y's with the passenger turbo just before going through the core support.
These parts were fusion welded because I like the way it looks and it's plenty strong for the cold side.
Old 03-27-2012, 07:50 AM
What kind of welder are you using?
Old 03-27-2012, 08:11 AM
INTMD8's Avatar
HTP Invertig 201
