Old 03-16-2012, 05:47 AM
eric36 eric36 is offline
Originally Posted by dubbleu View Post
Ok I did some measuring and the one in the link above is two inches too wide. So I called them up and he's got one for the 69 camaro that measures around 10 inches wide at the widest point. Should fit great. My order is in!
I will see if I can get some pictures off of him.
Did you end up getting one?
1969 Chevrolet Camaro
Dse / Marquez / Recaro / Budnik /Nitto
1970 plymouth Gtx
Old 03-16-2012, 07:46 AM
Depthrecordings Depthrecordings is offline
Those are pretty sweet. Looks expensive for what it is though. Have you considered building one yourself? I'm designing one now for my 67. I plan on using fiberglass and foam over a round bar frame. I will follow up with details.
I would love to see some pic of what other have done with their consoles as well.
Eric Bernal
Denver, CO
67 Project Camaro
Link to my build:http://www.camaros.net/forums/showthread.php?t=202010
Old 03-16-2012, 08:40 AM
dubbleu's Avatar
dubbleu dubbleu is offline
I put my order in. Just waiting for it to show up. I will post some pictures of it when it arrives.
Old 03-16-2012, 08:58 AM
parsonsj parsonsj is offline
I've got a 69 project going too. I'm considering the MCI. Watching this thread!
John Parsons
Old 03-16-2012, 10:51 AM
dubbleu's Avatar
Here's the e-mail I received the day I ordered. It looked good to me so I went for it. Should see it here soon I think there were only a few orders ahead of mine.
"This console comes as you see it, the front and top of the tower will need to be cut to fit your car.
It is about 30 inches from the back of the arm rest to the face of the tower and it is about 10 inches wide on the face of the tower.
Check your measurements to see if this will work for you. The top of the tower ( after the cut to fit ) should meet the dash just behind the bottom of the ash tray and the back of the arm rest should sit above the seat belt bolts on the tunnel
We will need to know what type of shifter you have before we can install the cup holders ,we have had some automatic set ups that won't allow us to use our cup holders, there isn't enough room for the bezel and the cup holder."
Old 03-26-2012, 02:45 PM
dubbleu's Avatar
Default Console
So its here and looks good. Once I trimmed it down to fit just under the dash. It ended up being about eight inches short (Does not go back between the seats far enough). Im going to cut it in half just in front of the storage compartment and add the extra length in.
Not a direct bolt in but lots to work with.
Old 03-26-2012, 07:25 PM
Did you inform the seller?
1970 plymouth Gtx
Old 03-26-2012, 07:50 PM
dubbleu's Avatar
No I didnt contact the seller. The seller never claimed it was a direct fit. Im more than happy with it. Like I said lots to work with and the end result will be nicer than if I had started from scratch.
Old 03-27-2012, 08:27 AM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
If you can try, Glass in a metal or aluminum strip on the inside area where you are extending it. Gives it extra strength. Nice looking shape to start with, Should work great.
TRACY WEAVER
www.recoveryroominteriors.com
Old 03-27-2012, 08:42 AM
dubbleu's Avatar
Sounds good. Thanks for the tip Tracy. I'm going to pick up some aluminum and fiberglass today after work and get at it.
