Old 04-03-2012, 05:42 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
That is some beautiful craftsmenship right there.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 04-11-2012, 05:35 PM
INJECTED69's Avatar
INJECTED69 INJECTED69 is offline
Verry Nice Build!
Injected69
Old 04-12-2012, 04:39 PM
garickman garickman is offline
Here is a couple of pictures of the engine mock up, we are in the process of making motor mounts. The engine has been set back about two inches and dropped down a little more than an inch.
Greg
Old 04-12-2012, 11:27 PM
that pigs gonna be a monster!!! looks good in black
Old 04-19-2012, 05:57 PM
Making the motor mounts and fabbing up the exhaust this week. Here is some progress pics.
Greg
Old 04-20-2012, 01:55 AM
MattO MattO is offline
What are the small blue pieces on the muffler brackets? I've never seen something like that.
"I should have just started smoking crack. Its just as addicting and WAY cheaper..." --unknown
Old 04-20-2012, 06:28 AM
High temp silicone grommets. The purpose of these is to issolate the exhasut system from the frame. Here is the description from the stainless works website.
" Are your exhaust grommets melting?? Blue "Snapper" Grommets-High Temp Silicone-these hold up better and are have the best heat resistance that we have found!!! Designed to fit around a strap with a 5/8" through hole, and use a 3/8" through bolt. 1 1/8" od, 7/8" thick. Works great for isolating exhaust vibration from mounting bolts when attached exhaust system to hangers and frame."
Greg
