Old 04-09-2012, 06:25 PM
jeepracer jeepracer is offline
theres really no set number that says what size engine you run, but the bigger the cubes the higher placed you are in the class. if i were to build a 377, it would probably place me in a class that is way faster. its very confusing...
theres drag racing and obsticle though. the drag racing is more heads up full throttle for 300 foot. where as the obsticle is more of a wide open/on and off for about a minute and a half, depending on the track. some tracks, there are really narrow turns and some have a couple hundred yards of space to race down. i feel that a high reving motor that is quick would be the best thing for it. there are many cars there running 283's that are at 7000 rpm for lond durations.
theres a guy that built one there that is a 302. he wanted to build a bone stock 302 and race it but he did some changes to it. it made, if i can remember correctly, 480 horsepower on alcohol. im not sure exactly on the internals but its pretty nasty. his runs really good but it has its week points and if i were to put better heads on it, i could make alot more. thats where the questions come in like what heads and the possibility of stock heads(worked). basicly the smaller the cubes the better, with alot of power.
i know alot of people say its a bad engine to build for what i do but i think its a really good combo. i wanna do this to kinda 1 up him too lol, for personal reasons that is
Old 04-09-2012, 07:17 PM
Okay -- so seriously -- building a motor is a lot more complicated than what you're asking.
Things like heads and flow rates etc have to match the cam choice - and the compression rate (static) and what RPM band etc (though you stated you want to see high rpms).
Thing like this need to be very well planned - particularly if you want to go racing and be competitive.
I wouldn't ask this stuff on a forum... you need to take your info - vehicle - weight - trans gearing - rear gearing - tire size etc to a REAL ENGINE BUILDER and tell him what you're after and see if you can do what you want to do.
Sound like fun!
Old 04-09-2012, 07:21 PM
badmatt's Avatar
badmatt badmatt is offline
Or go pick up an EX nation wide or cup motor... 800ish HP, 358 cubes stupid rpm...
like I did.
Old 04-09-2012, 07:38 PM
nascar engine would be awesome
but i could go straight to my engine builder and ask him but i figured id come on here and see if anyone is running a similar setup. maybe something as a daily driver or a full out race motor. there is not much reference for these 302s.
Old 04-09-2012, 09:19 PM
fleetus macmullitz's Avatar
This one sounds nasty at 8500.
Old 04-10-2012, 01:51 AM
CrossRamRich's Avatar
CrossRamRich CrossRamRich is offline
Dimitri Elgin built a 302 that reved to 10,000 rpm in the late 80's for a friend of mine that was in a jeep sand dragger named "The God Father". Iron headed, crazy fast, Elgin is in Santa Rosa, CA, I believe. He is an amazing guy, still remembers the cam specs! Give him a call.Elgin Cams.
Rich Bermea
Road Touring Customs
Gilroy, CA
Old 04-14-2012, 07:01 PM
i just picked up a 283 for 250. i was told it was a 327 but its not. im gonna keep the crank and look for a 327 block
