Old 04-26-2012, 11:28 AM
skatinjay27's Avatar
I'm not sure where you'll be, but come find me... I'll be in the area called the WINNERS CIRCLE.
man dave did you get your spelling lessons from rodger!
the word you were looking for is spelled WIENERS
AJ
Old 04-26-2012, 07:11 PM
Dropped off new rods and talked to Mike about heads, intake, and cam plans...
The good news.... heads flowed right at what I was told they flowed.
Lift / Intake / Exhaust
.100 75 53
.200 149 106
.300 226 158
.400 264 212
.500 326 234
.600 358 247
.700 369 255
.800 373 258
.900 366 260
.975 366 262
The bad news... I need new springs, retainers and keepers, but I was kinda factoring that possibility in when I got the top end so damn cheap. He likes PAC springs and the titanium stuff.
Mike will run some more numbers and plug into his Cam Doctor but he's thinking about 266ish intake and low 270's exhaust duration @ .050 and peak net life in the .675 range. He is most concerned with the mid lift area of .200 to .600 and these heads do pretty well there for 20+ year old Nascar crap.
He also specs his cams with the Ford Cleveland firing order (again, Nascar) and apparently it's a 4 cylinder swap deal. First I have heard of that, but he's the boss here.
He said the weak link in my parts is the intake and he'll have to do a little work with it so it isn't such a restrictor it's hurting the combo. He'll put the heads with the intake back on later toward the end he said.
I'm having a lot of fun showing up at the shop and talking and learning from these guys. It's a lot of info to take in and retain for me but I learn some things each time I talk to or meet with him. The uber technical workings are not my strong suit.
I may pony up for some valve covers from them. Not sure yet.
Old 04-26-2012, 07:47 PM
badmatt's Avatar
badmatt badmatt is offline
Get the springs ISF , cryogenicly treated or REM'd it does make them live longer.
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 04-26-2012, 07:53 PM
intocarss's Avatar
Sounds like you'll be Snappin' Necks, and Cashin' Checks in no time PAH!!!!
Splurge and get the VC's you owe it to yourself and those look nice!!
BTW I have a set of used low runs Ti retainers for double springs, If they'll work for your app you can have them. What size valve stem are you running?
Old 04-26-2012, 08:18 PM
Didn't know that was done to springs. The gears in my trans have the REM treatment though.
Thanks Jer. Not sure whose checks I'll be cashin tho.
And thanks for the offer on the retainers. I do not know the specs yet but I'll get some numbers from Mike next time I'm there. You're a good man Charlie Brown.
Old 04-26-2012, 08:42 PM
intocarss's Avatar
BTW I will also have to know the ID and OD of your springs too
Old 04-26-2012, 08:53 PM
Sieg's Avatar
Sieg Sieg is offline
Considering the amount of time you'll be spending in the weiners circle you should probably negotiate a sponsorship agreement with the builder.
Ron in SoCal's Avatar
Really like those flow rates. Beefy in the middle and keep flowing all the way to the top....
Get the Ti locks and keepers. It's better on your valve train! Jerr Dog's our resident motor expert and goodwill stand, so PM him if you ever need a little backdoor tech. (easy Jerr, I'm talking about motors here )
Ron in SoCal
69 Camaro in progress
Old 04-26-2012, 09:02 PM
Track Junky's Avatar
Blah, Blah, Blah...........just hurry up and finish this thing so we can go out and play
Gaetano Cosentino
Old 04-26-2012, 09:03 PM
intocarss's Avatar
DAMN Seig is talking about weiners and Rons talking about back dooring. Your all a bunch of teases!! I don't know how much of an expert I am but I try to help
It's all about Racers Helping Racers. BTW Ron... did you see that 2000Hp+ twin turbo eng over at QMP the other day HOLY S**T and that was with only 18 # of boost
DAMN NICE STEERING WHEEL DAVE
see no high jacking going on here
