Old 05-08-2012, 06:55 PM
Had a great hour with Mike B the shop today. Man I learn a ton there.
Updates:
-Roller bearing 50mm cam tunnel is bored
-Deck was not square (shocker) so they are squaring it up. He said he'll likely bring it down from 9.0225 where it sits now just to 9.000 and call it good.
-Diamond hone up next
-His assessment of the block is that he likes its water jackets, its priority oiling and he compares it so far to the Little M, so I liked hearing that
We knew my Jesel shaft rockers would need some attention (new adjusters, maybe some rollers) but we did discover the intake is a 1.7 ratio (not 1.6 as advertised) and that's a good thing for cam design. 1.6 is exhaust as sold.
We talked cams in detail and he is a big believe in these oversized base circle cams, either 50 or 55mm for SBC. He showed me a shelf Comp Cams Mopar cam with standard base circle next to one he designed and had cut with a monster base circle (don't know Mopar sizes) but the difference was staggering. And what he said that was really staggering was the larger one made 60 more hp on the dyno. No other changes. Same cam specs. Wow. I had no idea on that stuff. So I'm sold on the added expense (a few hundred bucks) for the larger base circle on mine. Done deal.
He also would not let me take a pic of the 2 Mopar cams side by side. Trade secrets.
I learned the "C" or Cleveland firing order is the same as the LS firing order (also called a 4 cylinder swap) and it's easier on the internals while making more power. He said that's why all or most of new modern motors use that firing order. He uses the 4-7 swap on tunnel ram setups.
Mike is so cool and old school.. he has the same credit card machine from 1989 he said. If it ain't broke, don't fix it! It is huge like the phone Gordon Gekko was holding on the beach in Wall Street.
Put the crank on the scale. Mike said weight don't mean nothin til it registers on his scale.
Old 05-08-2012, 07:03 PM
Track Junky's Avatar
Nice....so whats left on the list as far as parts?
Gaetano Cosentino
Old 05-08-2012, 07:06 PM
I love the engine building stuff. It's my favorite part of the build process. I've offered to sweep floors around Jason's place a few times.
Old 05-08-2012, 07:08 PM
coolwelder62's Avatar
Is that one of those LS block's Cast in South America.It doesn't look familiar.
Old 05-08-2012, 07:09 PM
89 RS's Avatar
89 RS 89 RS is offline
Thanks for sharing Dave, good stuff!
Corey
1989 Camaro RS
Old 05-08-2012, 07:10 PM
Carb will be here later this week. And Mike has to order cam and pistons. Then it's just the little things like bearings, accessories, carb spacer, and installation. They are super busy at the shop so now sure how quickly it will get done, but at least my parts search is not any hold up now with the crank being here. I think he said cam and pistons take 1-2 weeks max once ordered.
I'll be bringing my pan, oil pump, timing chain, distributor, and damper over there soon and hopefully they all pass his inspection.
Yeah man this is a blast. I think I'm gonna make a stop weekly at least to Mike's even if I don't have anything to say or pick up or drop off.
Old 05-08-2012, 07:11 PM
Heck it might be. Now you got me all freaked out Scott!
I got nothin to teach people, so I'll just pass on the good stuff I'm getting from Mike.
Old 05-08-2012, 07:17 PM
I think I saw them using the very style motor in the new Fast
5 movie.
Old 05-08-2012, 07:28 PM
Ron in SoCal's Avatar
Roller bearing cam tunnel?
Diamond hone?
Nice...
Ron in SoCal
69 Camaro in progress
badmatt's Avatar
badmatt badmatt is offline
whooooooooo!
Parts look awesome Dave!
97 Sonoma "NERA": Pile O Sh*t. Literally.
