Old 05-04-2012, 07:02 AM
Ralphlovs72chev's Avatar
Ralphlovs72chev Ralphlovs72chev is offline
Nice story.... it is looking really good at this point.....
Old 05-10-2012, 10:35 AM
MoonMan's Avatar
MoonMan MoonMan is offline
Thanks Ralph!
Here is more of the progress...
DSE mini tubs and roll cage installed
Firewall smoothed
Side markers filled
Old 05-10-2012, 12:12 PM
MoonMan's Avatar
I never was a fan of the quarter “overhang” so the quarter-to-tailpan seams were welded smooth
Instead of welding the plates to permanently hold the subframe to the connectors I opted to make it bolt in so the front subframe could be removed.
Old 05-11-2012, 12:59 PM
MoonMan's Avatar
Next up was the (slightly) narrowed rearend.
4-Link brackets being welded in place
Axles and coilovers installed
Old 05-11-2012, 02:27 PM
MoonMan's Avatar
On the rotiserie for the bed liner undercoat.
Old 05-11-2012, 05:21 PM
John510's Avatar
John510 John510 is offline
Nice car. Rendering reminds me of F-Bomb
[SIGPIC][/SIGPIC]
Old 05-11-2012, 08:17 PM
Looking good.
Old 05-21-2012, 10:19 AM
MoonMan's Avatar
Thanks guys!
The last modifications…then bodywork could start. A RS header panel was grafted with the standard one to create a spot for the indicator lights since the standard openings would be used for cold air induction.
Here is the “collector” for the air. It will eventually feed into a central, filtered air box.
Lastly, I wanted to go with split bumpers but always thought they could use a little heft to them. There were a couple 67 Camaro bumpers lying around so my friend cut and stitched them together to see what it would look like.
Old 05-21-2012, 12:06 PM
MoonMan's Avatar
I picked up a LS1 from a ’00 Corvette with 10k miles. The guy I bought it from was building a Factory Five GTM and bought the wrecked Vette for parts. His original intention was to use the LS1 but after making enough money parting out the pieces he didn’t need he decided to buy a crate LS6 and sell the LS1.
Using a set of mounts and an F-body oil pan from BRP we mocked it up in the car, along with the DBW pedal. It was now time for bodywork so I took the engine home for some upgrades.
Once home I replaced the cam, springs and pushrods with the Texas Speed 228R kit. I then cleaned it up and spray bombed it Cast Aluminum and Satin Black.
Old 05-24-2012, 03:32 PM
MoonMan's Avatar
Prime, block, repeat
Once the lines were crisp, panels flat, and gaps tight it was final blocked and disassembled for paint. Subframe, rearend housing and suspension sent for media blasting then powdercoat.
