Old 05-12-2012, 07:19 PM
Originally Posted by chr2002ca View Post
You could try wrapping the carrier in several layers of Dynamat. It worked great on the whining noise my first wife made.
That's a winner.
Old 05-12-2012, 08:02 PM
coolwelder62's Avatar
If the gear set is whinning when power is on,& no noise when off the throttle this is an indication it's time for a new ring & pinion.
Old 05-12-2012, 08:04 PM
FETorino's Avatar
FETorino FETorino is offline
Its time to change the oil anyway swap to Lucas 85 / 140.
If that and some more break in miles isn't quiet enough plan B.
Rob in SoCal
Old 05-12-2012, 08:10 PM
hulsund hulsund is offline
Is whinning when i cruising on the higway ,will try to change oil and use 80-140
Old 05-12-2012, 09:43 PM
Since when should properly set up gears whine? I've never heard a peep out of mine. Of course, my cars not a kitten either.
Old 05-12-2012, 10:58 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Yeah, but even if it did, we certainly wouldn't been able to hear it over the whining about brake pad knock back, or valve lash, or whatever else has to get changed out on big blocks frequently
Matt
Old 05-12-2012, 11:04 PM
Originally Posted by ratman67 View Post
you must be running a pansy exhaust system if you can hear anything other than the engine...put some free flowing mufflers on the car, then buy a mans sound system and let her rip, problem solved....
Did I read/hear that 9 inchers are more prone to this noise than 12 bolts? Thought I did....
Old 05-12-2012, 11:08 PM
Matt
Don't change the subject.
I was wondering the same thing.
Old 05-12-2012, 11:21 PM
Matt@BOS's Avatar
Alright, so I've never actually heard mine make a whining noise. However, I have heard it make a popping/clanking noise once or twice when pulling away from a stomp, same goes for Bad Penny. A little disconcerting but they're still going strong.
Matt
sixnina's Avatar
sixnina sixnina is offline
What do you expect when you put a ford under a Chevy?
