Closed Thread
Old 05-16-2012, 10:29 PM
FETorino's Avatar
FETorino FETorino is offline
What do you expect the curb weight to be?
Stock weight with the FE was 3537 lbs. AL radiator, block, intake and water pump put my motor at the SB weight of 3200 lbs or less. Then I have to add back some weight for the full frame chassis.
Long story short. I'll know when I weigh it.
Rob in SoCal
Old 05-16-2012, 10:32 PM
That doesn't sound too bad at all actually. You doing a cage? Full?
Old 05-16-2012, 10:38 PM
FETorino's Avatar
Yes. The new chassis intrudes into the stock floor behind the front seats in the passenger foot well. Phil and the boys are adding a tie in point for the main hoop on the chassis at that point.
I haven't decided wether I'm doing a full cage or just a 4 point.
Rob in SoCal
Old 05-16-2012, 10:58 PM
Man with that kind of power and chassis I'd go full for sure. RS could do a sweet one you'd barely know is there.
Old 05-16-2012, 11:08 PM
intocarss's Avatar
Is Phil Mandella building your car?
Old 05-16-2012, 11:28 PM
FETorino's Avatar
No. The Roadster shop is doing a chassis for me along with minitubbing and some other fab work.
http://www.roadstershop.com/current-...-s-1969-torino
Blair Patrick is doing my motor.
I'm the PM, parts chaser and assembler.
Greg Weld is tasked with wheel choice.
Rob in SoCal
Closed Thread
