Old 05-20-2012, 05:31 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by JSM View Post
I completely agree, safety first! May wanna just shelf the mag and drop the necessary funds for a Quicktime?
I am not so sure a trans blanket is the correct application for the road course anyhow.....I am thinking the blanket will trap heat and raise tranny temps?
I think a good quality kevlar trans blanket may approach the cost of a new quicktime.
You have a SBC it's not like a steel skattershield for a SBC is hard hard part to find used at a good price. JMO I like things simple so I'd just go steel scattershield and not look back.
Rob in SoCal
Old 05-20-2012, 05:39 PM
You ain't gonna beat me no matter what you weigh... might as well go and load up on excuses.
Save your money -- Susie is going to need it <for shoes>
Old 05-20-2012, 07:01 PM
Yeah that might be an issue huh. I'm looking into the Quicktime as well. Thanks.
True. I see them all over so that won't be an issue. It's always nice to just use what you have laying around.
Oh I see you have changed your stance from sandbagger to frontrunner.
She does love her some nice high dollar running shoes.
Old 05-20-2012, 08:27 PM
Sieg's Avatar
Sieg Sieg is offline
I'd go safety first, it's recreation. Legs are my primary concern and fire factor is the second.
Do you know the weights of the mag and Quicktime?
Old 05-20-2012, 08:29 PM
No scale at the shop but everything points to about 8 lbs for mag, 11 for aluminum and 20-24 for steel variations.
Here's a Tilton in steel @ 24 lbs.
http://www.stockcarproducts.com/tilton4.htm
Old 05-20-2012, 09:07 PM
intocarss's Avatar
100% correct And I've never seen a trans blanket that covers the bell housing also how to you run a trans blanket with a stick? it'll have to go under the shifting rods
Old 05-21-2012, 12:15 AM
FETorino's Avatar
That would be a NO vote for magnesium.
Rob in SoCal
Old 05-21-2012, 12:45 AM
Yeah that does seem to be the case after further review.
Matt, you still gonna run a blanket with your 4 speed?
I concur!
Old 05-21-2012, 12:57 AM
Dangit I just missed this one for half price.
http://www.racingjunk.com/Manual-Tra...y-RM-6010.html
Old 05-21-2012, 11:47 AM
I think Prada makes a bell housing protector.... Or maybe it's Jimmy Choo?
