Old 05-25-2012, 04:37 PM
Yenko68 Yenko68 is offline
Default 408 sbc 1st Gen testing the waters
Thinking about going another route. Might be looking to sell my current complete motor. 408 SBC 1st gen never fired up yet. list of parts on motor. Over $4,200 invested. Might have more parts this is a rough price and list off the top of my head. Thinking about asking $3,700. Let me know A similar motor in"How to Build a Big inch Mouse" using vortec cast iron heads and same 268 Comp Cam with only 9.5 comp made 428Hp @5,400 RPMS and 520 Ft Lbs @ 3,200 RPM's
2 bolt block
Moroso oil pump$75
Moroso 8 quart pan $ 165
Edelbrock RPM heads 6089's $975 with Mild port job $1200 invested
Edelbrock Victor Aluminum water pump $175
Aluminum Roller rockers 1.5 $ 175
Cloyes Hex-adjust timing chain $ 130
Speed Pro hyper piston w/ rings 10.1 comp $275
Holley 110 GPH Fuel pump $80
Edelbrock RPM intake $ 155
Eagle 6.0 rods $ 370
Eagle forged Internal balanced Crank $575
Comp push rods $145
Comp 268 xtreme with comp lifters $250
Complete ARP bolts $150
ARP main studs $25
Head gasket for nitrous $100
Centerforce 2 clutch and pressure plate $240
153 tooth flywheel
TCI rattler harmonic $330
Not to mention the machine work and labor .....
Can send pictures...
Text Cell #760-382-1164
Thanks Lenny
