Old 05-29-2012, 06:54 AM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Default Which plugs would work best
Just wanted to see if any of you would have a idea on this, What heat range spark plugs works best for a 364 Buick nailhead, With 10.5 to 1 compression, There has been a debate over the weekend
TRACY WEAVER
www.recoveryroominteriors.com
Old 05-29-2012, 10:18 AM
Try some wine bottle corks....
Old 05-29-2012, 10:51 AM
Sieg's Avatar
Sieg Sieg is offline
Natural or synthetic?
Old 05-29-2012, 11:00 AM
Supporting Vendor
White or Red .......I should have expected this
TRACY WEAVER
Old 05-29-2012, 08:34 PM
ivmotor ivmotor is offline
Haha, I know its off topic, but...
What brand spark plug?
What's in the engine?
Will it see WOT for any length of time?
My $.02 says go hot. Very rarely do we run into too hot a plug for street cars. Extended tip 5-6 heat range (autolite) spark plugs don't foul easily and will clean up. If somebody runs nitrous or boost we will drop the heat range down into the 3-4 range if we know the dude's gonna use the motor for evil. Cold plugs are a pain in the ass for show cars. They foul so quickly and won't come back even with the "high arc" technique. Early combustion chambers and carbs are really bad for fuel puddling which will kill the plug instantly.
I like the boxed wines!
Old 05-29-2012, 09:27 PM
Supporting Vendor
Thanks, ill try the Autolites on the hot side. Its a stock motor. .....Crown Royal beats wine anytime
TRACY WEAVER
