Old 06-06-2012, 07:28 AM
Golden_pilot Golden_pilot is offline
Default Prodigy Bar
I bought a Prodigy Bar from Frank back in 2010, which I just got to putting on a couple months ago all to find out it doesn't have the right bushing for the bottom of the QA1 shocks or spacers for the top and bottom bolts. I have tried for the last two months to get Frank to send me the right parts but thats turning out to be a lost cause.
Would anyone know of the part number for the lower bushing where the QA1 connects to the Axle? If anyone has a couple pics that would help to.
Old 06-06-2012, 07:38 AM
pw2006's Avatar
pw2006 pw2006 is offline
Try calling Ridetech, they may be able to help.
Rob
69 Camaro PT project- LS3/4L70e, Budnik's, Ridetech, Speedtech, Wilwood, DSE tubs, 4 link, shortened Moser 12 bolt- in progress
Old 06-06-2012, 09:07 AM
dhutton dhutton is online now
X2. Ridetch has all kinds of bushings etc listed on their website.
Old 06-06-2012, 09:45 AM
It's really a Air Bar so I agree that Ridetech likely can help you. You can source it through QA1 and Allstar performance as well.
Old 06-06-2012, 10:45 AM
Chassisworks Chassisworks is offline
Supporting Vendor
Golden Pilot,
You may have a Ridtech Airbar or you may have a Chassisworks gBar. Frank sells both versions.
If your suspension looks like the one below I may be able to help you. If so, give me a call at the number below. Ext 247.
Old 06-06-2012, 08:15 PM
Thanks guys I did call Ridetech about a month ago but they said they don't deal with QA1 shocks and couldn't help me. It's the Ridetech airbar that I have. The top bushing which is 1/2" fits the bolt but slides back and forth so it needs spacers or a wider bushing and the bottom bushing which is 1/2" needs to be I believe 5/8 to fit the bottom bolt and possibly spacers but I'm not sure.
Old 06-06-2012, 08:24 PM
Originally Posted by Golden_pilot View Post
[IMG]file:///Users/jordanhakeman/Desktop/IMG_0993.jpg[/IMG]
[IMG]file:///Users/jordanhakeman/Desktop/IMG_0996.jpg[/IMG]
you have to do these pics as attachments since they're in your computer and not on the net. Scroll down to the manage attachments button and upload them.
Old 06-06-2012, 08:32 PM
Thanks camcojb!
I'll try and get some better pics.
Old 06-06-2012, 11:02 PM
Take my advice on the spacer sourcing and ridetech will sell you the lower shock stud in 5/8. I just bought one two months ago.
Old 06-07-2012, 05:12 AM
Supporting Vendor
The lower stud in the image is 5/8".
Here's the lowdown on an AirBar:
Upper Mount: 1/2" double shear mount; 1.25" wide
Lower Mount: 5/8" single shear mount; 1.25" wide (1.375" wide without washers)
NOTE: Minimum diameter for single shear mount is 5/8" on loaded applications!
It appears as though the QA1 shocks you have use a 1/2" ID bearing X 1.0" wide.
Our coil overs and Shockwaves use a bearing with a standard 1.0" OD and a 5/8" ID. We then use spacers /adapters to match the mounting hardware and match the almost industry standard 1.25" mounting width.
To do this correctly you need to purchase bearings and spacers from us.
Bearing (if your shocks use a 1" bearing bore):
http://www.ridetech.com/store/index....roducts.search
Spacers:
Skunk Werks
Ridetech
www.ridetech.com
