Old 06-07-2012, 01:49 PM
Z10ROD's Avatar
Z10ROD Z10ROD is offline
NICE BUILD I'M watch'n !! mine's slow or maybe my driving skills R BAD
https://www.youtube.com/watch?v=R0_P02ie47Q
Old 06-09-2012, 05:53 AM
johns cuda shop's Avatar
johns cuda shop johns cuda shop is offline
cool video
Old 06-09-2012, 06:07 AM
Hey John, very creative on the lic plate! Great job Thanks for posting.
Old 06-22-2012, 04:38 PM
Thanks Al.. Here are some battery box mods. I sunk the battery as low as I could in the trunk. I wasnt happy with any battery holdowns that I saw ,so I made my own from some aluminum.
Old 07-14-2012, 03:59 PM
I proceeded to remove the drip rails on the car. Since the the pinch weld was gonna be cut off too, I cut the drip rail in 2 inch sections putting a tack weld between each. Then I cutoff all the remaining drip rails. This way I have no suprise when the drip rail is cut off.I left it unfinished for now as I want to weld everthing together fully when the car is upside down on the rotiserie, I try to avoid upside down welding whenever possible.
Old 07-14-2012, 07:24 PM
joe440's Avatar
joe440 joe440 is offline
car is looking great, lots of detail. Giving me ideas for mine. good luck
Old 07-20-2012, 04:20 PM
I modified a 68 Chrysler imperial power trunk latch assembly to fit the cuda.This will be operated from the dash with a hidden switch , I welded up the trunk lock on the tail panel for a cleaner look
Old 07-21-2012, 07:32 AM
67XR7's Avatar
67XR7 67XR7 is offline
Great build! its hard to not like Mopar's especially when there is a lot of custom fab work.
1965 Chevelle, Pm me if interested in wheel tool rental
Old 07-21-2012, 12:09 PM
SuperB70's Avatar
SuperB70 SuperB70 is offline
This is a great build, I like what you have done so far.
Skilled fabrication. Keep it up!
About your trunk opener, sence your battery is in the trunk you'll build some me hanical opener also?
, Juhani
Old 07-21-2012, 03:36 PM
Yeah, I am thinking about adding a lever rod under the car, I also plan on having the battery terminals offset to the underside of the car just in case the battery goes dead, this way I can charge the battery without opening the trunk
