Closed Thread
Old 06-20-2012, 08:38 PM
Cole Cole is offline
Banned
So what time should I show up?
I second that...
Nice wheels Todd!!!
  #2952
Old 06-21-2012, 12:33 AM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
Wow, those are nice.
Didn't know you were looking for new rims. I missed the post and have not gone back to check the reasoning.
Can you fill me in on what prompted the switch.
  #2953
Old 06-21-2012, 12:35 AM
I think they call it excessive consumerism.
  #2954
Old 06-21-2012, 12:45 AM
Ok, I'll buy that. I want to see them on the car.
  #2955
Old 06-21-2012, 12:51 AM
Patience my friends, patience.
  #2956
Old 06-21-2012, 04:25 AM
uk68327's Avatar
uk68327 uk68327 is offline
I suffer from that, wonder if there is therapy for it?
Mark
'68 Camaro
'93 Golf Rallye
  #2957
Old 06-21-2012, 09:42 AM
FETorino's Avatar
FETorino FETorino is offline
Call him Emelda Marcos, he just can't stop buying shoes.
Waiting............
Rob in SoCal
  #2958
Old 06-21-2012, 02:44 PM
frojoe's Avatar
frojoe frojoe is offline
Geez those are sexxxxxy
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
  #2959
Old 06-22-2012, 12:48 AM
89 RS's Avatar
89 RS 89 RS is offline
Those wheels are freakin' awesome.
Can't wait to see the new look!
Corey
1989 Camaro RS
  #2960
Old 06-27-2012, 12:04 AM
A big part of no mechanical failures is due to preventitive maintenence. The decision I made to check the valve springs saved me a costly unneeded rebuild. While I had the engine apart to swap out the valve springs and rebuild the lifters with the superior NO needle bushings, it was time for a good inspection and tune up. A consistent compression balance and clean plugs showed me the combustion chamber is happy. I replaced the cap, rotor, plugs, and distributor gear along with inspecting the wires and blowing out the distributor housing. I looked the carb over and checked all the fasteners. I replaced the K&N with a fresh element. They are inexpensive enough that I decided to replace it vs. clean an reoil it. I dropped the visclosity in the engine to 10w40 to drop the cold oil pressure and reduce distributor gear wear.
I picked up another trick tool from LSM racing to do the valve spring change. It was a back breaker but I knocked them all out in a couple hours. Now I have a real baseline for fresh valve springs with my on engine valve spring tester. It turns out that only two of the old valve springs had really lost any significant pressure. The intakes measure 230 and exhaust 210 on the seat.(The values are different than they would measure off the engine) The exhaust lifter I nearly lost was only down to 180 seat. They will be getting checked at every valve lash adjustment.
She's running great and ready for a couple more years of raising hell before similar maintenence.
Up next is a trip down to Best of Show on July 23rd to have Dick and the crew freshen up the paint. Cut and buff and touch up some blemishes.
Closed Thread
