Old 04-07-2006, 12:55 PM
Steve1968LS2's Avatar
Well the project should be moving FAST now since we have programing lined up for the LS2. The dyno stuff should happen in the next 1.5 weeks.
The new firewall has been bonded on and will be welded on Monday. The new trans tunnel has been welded in place along with the transition.
All holes have been cut in the firewall (brake master, steering column, clutch master). The ATS bracket made installing the clutch master a breeze!
In less than two weeks the whole deal will be painted and the undercoating done.
The subframe from 21st Century is at the shop now and I will start bolting on parts next week. I need to figure out a way to weigh it.
Rick's Hot Rods is finishing up my new tank and all the other parts are in my garage except the new guages. There might be light at the end of the tunnel..
Old 04-07-2006, 12:56 PM
Originally Posted by 69MyWay
Looking slick!
Here is a challenge for you.
Is it possible to sheetmetal trim the inner upper horizontal lip of the fender so that it is smooth and slick from the exterior lip going into the engine bay? I had thought about doing this on my car because that is an unattractive area that I don't see anybody doing anything about.
I don't know if I am following where you are talking about..
Did did cover over the holes where you can see the subframe jam nuts since that was an unsightly area I hated to look at..
Old 04-07-2006, 07:18 PM
Originally Posted by Steve1968LS2
Did cover over the holes where you can see the subframe jam nuts since that was an unsightly area I hated to look at..
You better pray your body nut for the subframe never breaks. That is a great recipie for un-happy Steve.
Looking wicked. I really do like the ultra clean race car look of a full sheet of metal.
Tyler
Old 04-07-2006, 07:23 PM
Sales@Dutchboys's Avatar
Looking good! thanks for the update...
-Paul
dutchboyshotrods.com
269-823-2967
Old 04-07-2006, 07:31 PM
Tyler
They are in great shape and once this sub goes in it aint never coming out.. it might as well be welded in.. lol
if I ever need in there I will holesaw my way in and then make a nice little plug for the whole.. I just couldn't stand looking in there..
Old 04-08-2006, 05:34 AM
Speedster's Avatar
Speedster Speedster is offline
Car is coming along and looking awesome Steve !!
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 04-09-2006, 06:48 PM
syborg tt's Avatar
looks awesome
marty-mj
Old 04-12-2006, 12:12 PM
So close to getting paint that it hurts...
Recieved my ATI super damper and ARP bolts today..
Two old guys at Best of Show Coachworks working on Penny.
Old 04-12-2006, 12:18 PM
Your getting there .......
269-823-2967
Old 04-12-2006, 01:49 PM
67Fastback 67Fastback is offline
Since I am gonna run the AeroCatch hood pins I am thinking of ditching the factory hood latch.
If so I will weld up the center of the closeout. This will give a much cleaner look.
Here are the latches I am gonna run
http://www.aerocatch.com/automotive-home.html
Nice - I've been sweating the likelyhood that I would have to use hood pins on my car - I hate them.
Here's an idea though. How about mounting them backwards with the pin attached to the hood and extending down and the latch grabbing it from the bottom = invisible?
Jeff
