ordered my master cylinder and prop valve this morning from performance online. about time!!!!!
finished wiring the dash bezel with the gauges and LED's in, now gotta do under the dash.
for now It looks like I'll be using the stock seats, have to drop the drivers seat off at an upholsterer and replace the center section cause of a rip.
Rene looks great! I had not seen the Aman digital guages (top of picture) available yet JK, mand looks very clean, how did you install the turn light Led's?
Just drilled a hole on the left and right side of the bezel and popped them in. They came in a small enclosure with a resistor already in there. Then just attach the negative to a ground and connect the correct wire from the factory plug to the positive side. I also put an led in for the high beam indicator, but that is installed where the factory one went.
Awesome thanks, looks very clean. happen to have a pic showing where the wire wil connect to? I am also doing gauges (mine are procomp I believe silver), but pretty similar.
They have a tool for the quick release fitting. its a pain without it sometimes.. I usually just remove the master & disconnect it from the pedals & leave it attached. I'm doing a 68 bird vert with LS1/4L60 right now. I'm almost done, but have put about 10 miles on it so far. Look forward to watching you progress on the swap!
