  #28
Old 07-11-2012, 11:28 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
while it doesn't appear that there is a lot done (at least to me anyways) i have been doing a lot on the car that i am just not going to show until the car is done as some of it might make it into a production run.
machined some bulkheads for the passenger side brake line and the driver side brake, fuel and return lines.
then finished the fuel lines back to the fuel cooler and trunk bulk heads and the brake lines.
the rear sections of fuel lines are covered in heat tape then cloth heat shrink.
then i started mounting the diff. cooler. there will also be a trans cooler on the other side in the same place.
