Old 07-22-2012, 12:57 PM
toddshotrods's Avatar
toddshotrods toddshotrods is offline
The push is on for me now to get most of my ideas underway, or at least mocked-up, to find out how it all works together, and where changes may be needed. I've been at it all week, sacrificing sleep for progress. Today, I cut the foam dash plug. Along with the shifter, and pedals, we have to hang the steering column, and the dash and electric motor controls, to find out just how little room there is inside that tiny cowl.
I like vehicle interiors that are design statements, not just traditional interior components with special coverings and finishes. I get why most need to be that way, but for radical custom projects, why not go beyond "normal" inside too? The major manufacturers do with their concept vehicles, and some of the higher end hot rod/custom builds go there. With Schism, I'm trying to make the interior look scupltured, like it was carved from stone, and hammered from metal, by ancient Romans and Greeks; more chariot than car. Now that we're starting to hang parts in there, that theme is beginning to become more perceptible, I hope...
The contrasting bare materials will be like an inverted image of these renderings, but I like how they work together.
Todd Perkins Design
Old 08-11-2012, 08:32 AM
Time to update. I'll try to keep the narrative to a minimum, and let the pics do the talking. The pedal assembly is coming along.
I modeled the throttle pedal pad, and cut a wooden plug.
Then had the casting guy at Columbus Idea Foundry (the complex we're being incubated in) cast it.
A little finishing work, and heat treating, and it will be perfect.
Todd Perkins Design
Old 08-11-2012, 08:39 AM
Chassis.
Those rear bars angle downward as they go back, kind of giving it a hardtail chopper look.
Todd Perkins Design
Old 08-11-2012, 08:54 AM
And finally, a roller coaster ride on the intake, but progress, none-the-less. I cut a foam plug for casting the plenum flange (the same day we cast the throttle pedal pad). First a test, then the actual plug.
I machined it in two halves, hot glued them together, cut a fixture plate in a scrap piece of wood, then hot glued the plug to it and cut the internal runners, while the ShopBot was still zeroed over the fixture. I simply snapped it off the fixture when that was done, and cleaned up the ends of the runners.
Then the casting process began.
Unfortunately, this one went bust. There weren't enough sprues (pour holes) and vents, and the gases and aluminum created new cavities right out onto the shop floor.
Like a good horror movie when they show an eye opening, or a hand twitching, this glowing crucible says we live to cast another day...
Todd Perkins Design
Last edited by toddshotrods; 11-03-2012 at 12:22 PM. Reason: typo - sprue, not screw
Old 08-11-2012, 08:57 AM
When I took a second look at the casting, I realized that the most important part of it had actually cast almost perfectly, so we milled the bad parts of, simultaneously milling the top and bottom flat and true. I actually like it more than the original design, so I am in the process of designing a new plenum to cap it off.
More to come...
Todd Perkins Design
Old 08-11-2012, 07:46 PM
Chevette Chevette is offline
Default You really do it all.
When are you going to start making your tires? Lookin' good, Todd.
Old 08-11-2012, 08:47 PM
Don't give me any ideas! Thanks!
Todd Perkins Design
