Old 04-13-2006, 05:18 PM
Todds69's Avatar
Todds69 Todds69 is offline
Now the question is which column are you going to buy. I'm going to be replacing mine here pretty soon, so someone to work out all the kinks would be great.
Old 04-13-2006, 07:18 PM
Speedster's Avatar
Speedster Speedster is offline
I chose a Flaming River stainless tilt column and the workmanship is excellent.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 04-14-2006, 06:30 AM
Payton King's Avatar
Default beat me to it
Scott,
You are a tall dude and the seats that you are running have high seat bolsters, you will need the extra room a tilt would provide to get in and out of the car....don't remember if you are running door bars or not.
I went with Flaming river tilt column and they have all of the tricky stainless u-joints and shafts to link up to the ARG rack. When or if you get the flaming river column make sure you opt for the $60 option of having the dimmer switch put on the end of the blinker stalk so you can eliminate the foot contol.
The columns come in either full polish stainless or one that you paint. The painted one is actually mostly stainless, just not polished.
On another note, the D shaft that you will need to get that goes between the U-joints on the rack and the column will come and you will need to cut to fit...which is good, because it will allow you to get the distance(depth) of the wheel/column where you want it which for you may be close to the dash.
The flaming river unit is also about the same size in diameter as the stock unit so the Marquez dash stuff will work.
Old 04-14-2006, 08:50 AM
Musclerodz's Avatar
Contact Borgeson, since that is there specialty. If you opt for the column, I would lean toward Flaming River as well because of their collapsable column for added saftey.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
