Old 08-06-2012, 05:42 AM
Rick D's Avatar
Rick D Rick D is offline
Oops double post!
Rick
Old 08-06-2012, 05:45 AM
Rick D's Avatar
Originally Posted by 67zo6Camaro View Post
Ask and you shall receive
Thank you Sir!!
Should I still post the blow by blow sets leading up to these photos?
Ummmmm yes please keep posting the detailed pictures and how to's
Just asking, so that I'm not considered the thread jacker. Lots of good photos of the clutch and flywheel (I mean flywheels) install with mating of the trans to the engine. Photos on the engine harness and American Autowire set-up and installation...
Speaking of double parts I here you will have one less housing to worry about
Rick
Old 08-06-2012, 06:50 AM
coolwelder62's Avatar
This build is coming along great.Ron,I hope you have it ready for RTTC next year.
Old 08-06-2012, 08:41 AM
Payton King's Avatar
Default Looks very nice
Did you install inner tube seals for the floater?
Old 08-06-2012, 09:22 AM
Ron in SoCal's Avatar
Originally Posted by compos mentis View Post
Them is some fine hard parts there...dawg.
Fo Shizzle ma Nizzle
Originally Posted by 73CPCAMARO View Post
The car is coming along very nicely. You guys are doing nice work. Keep the photos coming.
Brian
Thanks Brian. Also appreciate you taking me through Mike's oiling set up at Del Mar. That helped me alot
I sure hope so Scott. I'm kinda done making predictions cause all my good 'friends' call me on it. How does the saying go, 'deadlines are made to be missed?'
Yes Payton we doubled up on them - center section and axle ends. Between that and the center vent I'm hoping we keep the gear oil where it should be. Probably a losing battle though...
Ron in SoCal
69 Camaro in progress
Old 08-06-2012, 10:24 AM
Default That should be fine
make sure you vent each tube between the seals and you should be fine. You should have a total of 3 vents.
Old 08-06-2012, 12:36 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Good point Payton.. We are currently machining a part to do this on my housings..
Brett- Doing a great job!
Cris Gonzalez
Old 08-06-2012, 01:01 PM
That's what I thought as well and requested. Speedway engineer said the axle vents were not needed based on this design. We'll find out soon enough...
Cris are you referring to the GMR housing? Do they run inner (center section) seals?
Ron in SoCal
Old 08-06-2012, 01:03 PM
Default Hey Chris
Sorry to miss you at Motor State.
Wish I knew the info first hand, but Randy Bell was having a problem with fluild pushing through the seals. The tube vents coupled with the center section vent fixed the problem...according to Ron's discussion with Randy.
I can steal information and ideas like no one else. LOL
Old 08-06-2012, 02:17 PM
Cris@JCG's Avatar
If Speedway is good without it then you should be good.. but IMO you might blow the inner seals because you are creating pressure inside of those tubes.. & you might want to find a way to put set screws inside to retain the inner seals.. But that is what I think..
With all the issues that I have had with BB's rear-end.. I worked with Jason(GMR) on making my own housing the way I thought would work better.. Carrys more oil, Does not need inner axle seals but designed a way to keep the oil in the center section, & allows me a surface for my three link.. Last week Jason delivered three housings.. More to it.. but will show the end product later..
Payton- I am sure we will catch up here pretty soon @ a event!
Cris Gonzalez
