Old 08-09-2012, 08:24 PM
James OLC's Avatar
Default 1969 Dodge Super Bee - Erica's Car
This is a project that I've been working on for the past few weeks and I thought I'd share it although it's very different - in a lot of ways - from what we're mostly used to. On the surface I'd say that this is going to be the evolution of a former drag car to a mild Pro-Touring style build. But deeper than that it's a lot more. Feel free to skip ahead past the back story if you're so inclined, the good bits continue below...
Circa 2003:
The car belongs to a very dear friend of mine named Erica; before it was Erica's it belonged to her father David who owned the car for something close to 20 years. Erica grew up in the Super Bee and saw the car evolve from a rough, raw, project to a legitimate 10-second street car. Back in the day it was black with flames, had Kirkey aluminum seats, and seemed to spend as much time on the back of a hook as it did on the road... David's nickname was Kid Kaboom for good reason. Around 15 years ago David and I started the transformation which, like most, seemed to be a constant process over the course of 6 or 7 years. Nearly every panel was repaired or replaced (at least once) and the black gave way to sublime green (but the flames eventually returned); the 383 was pulled in favor of a well built 440 topped with a couple of stages of nitrous and parts that were historically grenades were replaced with bulletproof pieces. Even the Kirkey's were eventually replaced with custom leather seats. When I last worked on the car - circa 2004 - it was fast, reliable, and obnoxious as heck. In a lot of ways I think that the car defined David and it was always Erica's and David's common bond through thick and thin.
A few years ago David came upon difficult times and title for the Super Bee ended up in someone else's hands on a "temporary" basis; it wasn't the first time but it turned out to be the last - two years ago last month David passed away and the Super Bee was believed to have been gone forever.
2003
It took over a year but Erica's mom (David's first wife FWIW) eventually tracked the Super Bee down and tried to hammer out a deal to buy it '69 back. We all know how cars can have emotional and sentimental value - the 'Bee had been a huge part of Erica's childhood so getting it back was really important to her - and her mom went to great lengths to get the car back. Eventually a deal was reached and the seller committed to getting the car in to "driving" condition for Erica (it had been sitting for the better part of a year at that point) and would ship it in a couple of weeks.
Weeks past and became months with promise after promise being made - parts were being waited on, improvements were coming, but don't worry it was all coming together. Finally, after four months of hollow promises and missed delivery dates the 'Bee was "done" and on its way. It was tuned, test driven, detailed and ready to hit the road!
2003
The car arrived in Calgary a month ago and it didn't take long to see that everything was not as it seemed... Cleanliness (or lack thereof) aside, the first indication that something was amiss came with the first turn of the key... with mild persuasion the car started but there was no throttle. It took a minimal amount of looking around to track down the problem - the throttle cable was broken and not hooked up. Probably because the custom plumber fogger intake and Demon carb had been replaced. En route to finding that we discovered that the hood hinges were gone. The manual valve body, reverse pattern 727 was gone, replaced with a stock piece and the entire custom 8 3/4 rear and had been swapped out for a similarly stock unit. The fuel cell had been removed, the trunk floor "repaired", and a stock tank installed. The old side exit exhaust was gone and a new replacement was put in its place. Some of this had been expected but some was a surprise - all of it was a disappointment.
Engine circa 2003
Regardless, I gave the car a once over in the parking lot to see if it was otherwise ready for it's required inspection (basic safety features... you know, headlights, turn signals, wipers, etc.) which was required for registration.
Headlights... nope. Turn signals... kind of, some times. Wipers... nope. It sucked to tell Erica that not only was there no way that the inspection was going to happen but from what I saw there was no way that I was going to let her drive the car as it was... The decision was made to drag the car back to my house where I would do my best to get the car in shape for it's inspection and make it something that would actually be a ride that she would enjoy.
A couple of days in to looking the 'Bee over and the magnitude of the task quickly became apparent... 20 year old drag shocks front and rear... big leaf springs with shackles... manual steering... manual drum brakes... no sway bars - anywhere... and the list goes on. And that's on top of remarkably poor workmanship that went in to the car over the last 4 months.
And that's how it begins...
2012
Progress will most surely be slow and probably in fits and starts. It's definitely going to be a low budget effort but given some time and some work I think it has a ton of potential.
But it's going to be worth it - as both a tribute to David and, more importantly, as part of Erica's healing. It's been a long time since I've seen someone so sincerely attached to a car and so emotionally vested in a project. It makes the work difficult for both of us at times but it will come around.
I'm not promising that the updates will be predictable, nor will most of them be as amazing or remarkable as some of what we've seen in other posts, but this is a special project and a story that I thought was worth telling...
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 08-09-2012, 08:45 PM
James OLC's Avatar
So attention started in the engine compartment because besides being 21 feet long this thing weight 4,000+ and making it move under it's own power was high on my list of priorities.
As above... circa 2003 (and 2010)
And as delivered - 2012
One of these things is not like the other... darn...
James
1969 Camaro - Dusty
Old 08-09-2012, 08:53 PM
James OLC's Avatar
Erica and her mom were told that (a) the car had been test driven just before it was loaded up on the truck and (b) that the throttle cable had been replaced... yeah... OK...
and they were assured that the car was in good, safe, drivable condition (suitable for a young lady to drive)... OK... I may be picky but I'm pretty sure that I'm not unreasonable in expecting at least a hose clamp on a rubber fuel line...
and really? taking the master cylinder and replacing it with junk? c'mon
James
1969 Camaro - Dusty
Old 08-09-2012, 09:00 PM
James OLC's Avatar
But it wasn't much better in back...
The fuel cell was removed and a stock tank installed in it's place
And the trunk was professionally repaired before
"Professional" was two pieces of corrugated tin from Home Depot and six tack welds... all on the one side of the square...
Not sealed, not even attached...
It need some clean up but at least there is a starting point to work from
James
1969 Camaro - Dusty
Old 08-09-2012, 10:20 PM
nvmyss nvmyss is offline
I'm happy to see a car come home, especially when it has so much sentimental value.
But the total swap and hack job is just wrong.
Good thing good people like you are still out there and helping others.
Adam
69 Chevelle SS 396 < --Sold
67 Camaro
06 2500 Dodge Ram Diesel
93 Beretta GTZ
04 S60R ..Gone
Old 08-10-2012, 12:43 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
You do like a challenge don't you.
Curtis
Old 08-10-2012, 03:10 AM
69x22's Avatar
69x22 69x22 is offline
Wow that's horrible! I'm glad that shes getting it back though.
Old 08-10-2012, 04:41 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Subscribed! My Dad was a Mopar guy and my step-brothers each had Bees when I was growing up... one had a 69 and the other a 70. I wish my Dad had kept his 71 GTX 440 that he bought new to this day.
This is going to be a fun build to watch! Good on you James for taking this project on for her!!
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 08-10-2012, 06:42 AM
Steve68 Steve68 is offline
thought I'd throw this up for a little nostalgia!!!
Found this at my grandfathers house in 2011, when he passed,
My uncle got this in the 60's when he bought one of his super bee's, he's had a couple,
The only mopar I remember him having was a 69 383 Road Runner LimeLight Green with polished ET's had to be the early 70's,
great story, cant wait to see for more pics, and the guy who did the work to it, we should go visit him and take his tools away, and tell him no,no,no!!!!
Old 08-10-2012, 08:50 AM
If I was anywhere near by, I'd come and help. This is a good thing you're doing James. Best of luck getting it taken care of correctly and back on the road for Erica.
