Old 08-16-2012, 08:42 PM
CarlC CarlC is offline
I wonder if another 5mph would cause the window to break?
Would they allow the windows to be open? I wonder what the aero effects would do vs. the rear glass staying put.
http:www.vaporworx.com
Old 08-17-2012, 09:17 AM
Lateral-g Moderator
Wicked burnout.
Old 08-17-2012, 09:21 AM
Ron in SoCal's Avatar
Props to the navigator too
Ron in SoCal
69 Camaro in progress
Old 08-17-2012, 01:13 PM
Steve1968LS2's Avatar
The aero with the windows down would be crap.. heck, I was driving a '67 with the windows down once and it popped the headliner (was older) at 120ish mph.
the window breaking would look pretty good on film though
Old 08-17-2012, 01:38 PM
sik68's Avatar
sik68 sik68 is offline
So who's going to be first to market with these for a 1st gen?
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 08-18-2012, 09:03 AM
glassman's Avatar
glassman glassman is offline
Tempered glass (7/32") holds up incredibly. Back glass popping out would be relative to the bonding to the body, modern cars are bonded in with autoglass polyurethane, 220 psi when properly bonded. Butyl tape like 8 to 12 psi (goes lower when its hotter, liquifies)
Interesting bout the air pressure; you are displacing so much air, so it creates more pressure inside the cab, i would think it creates a vacuum. Its an airline equation right?
Bout the hp chart, with the 3:50 and sixth gear, 243 with 685 rwhp, its only in theory, the Veyron, aero'd, 1100 horsyish, does 250. I read somewhere once where it takes an additional 100 hp +/- to increase 10 mph or so above 200, think about how much the air compresses and how it exponentially corrects itself. SIMPLY AWESOME!!!!!
Did i spy the Finchmobile on the side in the run down?
Old 08-18-2012, 10:22 AM
WSSix WSSix is online now
Correct. The air passing by the car creates a low pressure point. The pressures inside the interior of the car are pushing the windows out. I don't think there is an actual vacuum involved though. Just greater pressure on the inside compared to outside
Old 08-18-2012, 04:31 PM
Thanks..
Next goal would be 180...
Old 08-19-2012, 08:47 AM
Steve, a couple years ago I swear there was an aerodynamics sticky on pt.com in advanced tech I believe. I read everything that was linked and found it very straight forward and easy to understand. It even talked about string testing and using two different gauges to monitor pressure differentials across say the radiator to help cooling capacity. Given that the car has no aero mods, you may want to look into adding some. I'm sure a belly pan of sorts would help and not change the way the car looks. It may even help with air flow through the radiator. The author of the links I read used a belly pan to lower his intercooler temps. It was just a matter of monitoring pressure differentials to ensure air was flowing through the engine bay.
