Go Back   Lateral-g Forums > Technical Discussions > Safety Equipment
Old 08-19-2012, 06:04 PM
BANKO's Avatar
BANKO BANKO is offline
Default Mounting height of harness bar?
Just wondering how far below the shoulder strap opening (in a racing seat) a harness bar/harness tie down should be? I asume he mount point should be equal to or within 1/2" of the seat opening. I didn't see any details in my harness installation instructions.
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
Old 08-19-2012, 06:40 PM
Ron in SoCal's Avatar
Not sure this will answer your question specifically, but it is chock full of good information:
http://www.hmsmotorsport.com/docs/Co...structions.pdf
I would also add these guys are GREAT vendors...
Ron in SoCal
69 Camaro in progress
Old 08-19-2012, 08:14 PM
Figure out your ergomonics when you'll be using the shoulder belts first. Then figure out at what level the belts will be going through the seat openings and mark the seats with some tape. I believe the spec is 0-10 degrees plus or minus but double check it.
Old 08-20-2012, 12:26 AM
intocarss's Avatar
www.gforce.com/pdf/Harness_Install_Info.pdf
Old 01-06-2013, 12:41 PM
DETON8R's Avatar
DETON8R DETON8R is offline
DANG, this is really good info.
How did I miss this??
Thanks for the links!!
DETONATOR - 69 Camaro RS
Old 02-21-2013, 08:37 AM
JohnUlaszek JohnUlaszek is offline
Another vote for HMS Motorsports. Joe spent a lot of time making me smart enough to write this story
http://www.gmhightechperformance.com...llbar_install/
<a href=http://www.iimuch.com target=_blank>www.iimuch.com</a>
II MUCH Web Store
