Go Back   Lateral-g Forums > Technical Discussions > Safety Equipment
Old 05-20-2011, 08:52 AM
Default Cold Fire
Many of the race organizations here in indiana use Cold Fire - in pit lanes and on-board race and support vehicles. It's non-halon - but it is a wet agent - so it probably makes a mess.
http://www.coldfireextinguisher.com/
http://www.botachtactical.com/fifrcofi12ca.html
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 07-22-2012, 05:54 AM
wrp's Avatar
wrp wrp is offline
For better or worse I am using a fixed mount Firecharger FFE system. Limitations include three nozzles only limiting you to two zones. I chose the driver compartment and fuel cell with the first system and am going to install a second in the engine compartment. Modified dirt trackers use this system around DFW. Went with it in lieu of Halon because of a concern that superheated Halon gases inhaled would/could result in burned lungs, have no idea if there is any truth to that but seemed plausible. So my problem now is with two systems covering three zones, trying to figure out how to discharge both systems simultaneously. I've seen some pneumatic pressure release arrangements but I'd have to give up an entire zone with two nozzles to use that. I also realize this system is not SFI because I can charge it myself but material handling was also a decision point. Also water soluble was a plus, thinking cleanup is easier.
Old 08-10-2012, 05:10 PM
sik68's Avatar
sik68 sik68 is offline
Hey guys, I'm trying to dig up more information on this new gas 3M 1230....apparently at least a few of the NASCAR teams are using it for their fire suppression...thoughts?
http://solutions.3m.com/wps/portal/3.../PressRelease/
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 08-10-2012, 06:11 PM
^ S -- I like it.... but where's the price?
Old 08-10-2012, 11:12 PM
FETorino's Avatar
FETorino FETorino is offline
Let's call them up and work out a group buy
It's the green thing to do.
http://automatedfire.com/services/auto-racing/
Rob in SoCal
Old 08-10-2012, 11:41 PM
SLO_Z28 SLO_Z28 is offline
Novec 1230 looks very good on paper. I had not heard of it until now, but its safe for the environment at least. I would definitely get a professional opinion from someone familiar with the system, I have my Cal-Fire and know just enough to know not to do anything you're not familiar with. As long as its 49 CFR 173.309 compliant and has its 17.1 cert id say it would likely be a good system, if it is professionally installed.
James F.
1974 Camaro Z28
Old 08-20-2012, 08:45 AM
sik68's Avatar
I've been nerding out on fire suppression and thought I'd share a few things i have picked up on. I'm not an expert but I did stay at a holiday inn express last night that was on fire...but fact-checking is most welcome.
History
AJ Foyt's team debuted the first on-board fire suppression system in 1967 at the Indy 500. He used Halon 1301, and it didn't take long for everyone else in racing to adopt the system using 1301. It was the standard for nearly 30 years in almost all forms of professional racing.
Halon 1301 had a big drawback though-that it has to be stored at HIGH pressure to keep it aqueous, which proved problematic in racing applications where heat and other harsh environment factors were causing accidental release failures. This is where Halon 1211 stepped in. With a much lower aqueous pressure and similar suppression effectiveness, it supplanted 1301. Here's the problem with 1211, it’s more toxic to breathe. In toxicology speak, it has a much lower LOAEL (lowest observed adverse effect level) concentration than 1301. Using the SFI 17.1 test procedure for enclosed driver compartments, a 5lb system will net you 12X the LOAEL for 1211, versus 1.7X for 1301. Once the SFI procedure was established and racing governing bodies adopted the standard (ie NASCAR) and saw toxicity ratios greater than 1.0 for both systems, Halons got BANNED. You may see that nearly all rule books today prohibit it.
DuPont, seeking to fill the void in the racing market, began promoting their FE-36 product, which is the trade name for the gas HFC-236fa. It passes the SFI 17.1 toxicity criteria with a ratio of 0.83, doesn't deplete the ozone like Halons (in the 1990s ozone depletion was another nail on the coffin for Halon), and best of all, it puts out fires just like Halons. DuPont's FM-200 (chemical name HFC-227ea) is also SFI tested and passed, and there isn't any meaningful information to distinguish it from FE-36. So what you will find are FE-36 and FM-200 are the DuPont products are on the short list of SFI 17.1 approved suppression systems.
3M is now recently in the racing market (last 12months) with their own gas C6F12O, trade name Novec 1230 which is now on the SFI approved list. Discerning if this gas is any better than the DuPont products is also difficult without really digging into the chemistry. The bottom line is there appears to be no citations of meaningful technical differences among FE-36, FM-200, and 1230, so I'm assuming that most racers will decide based on price points. If someone knows more than me on this please fill in the blanks.
Powder vs Foam vs Gas
This issue really has been the core of the discussion on the forums. I believe we can all agree that there is no bad choice. Even an ABC handheld extinguisher sometimes has its advantages over suppression systems, in that you can fight the fire from outside your car (or in a moment of racing comradery, your competitor's car).
Handheld Extinguisher
Here's a great story from my father, who owns child care centers and transports 14 kids at a time to and from school each day. He has a fire extinguisher mounted in the 15 passenger van on the leg of the first bench seat where the 'big kids' sit. One of the hooligans got bored during the drive one day, pulled the pin out and wanted to see what would happen if she kicked the handle with her foot. It was depressed for at most 2 seconds, but the powder quickly dispersed and FILLED the whole van in seconds. Visibility was 0 and so was breathability...the powder induces heavy coughing and discomfort. Fortunately he was going 5mph in front of a school at the time, came to a stop and everything turned out fine, but it could have been a lot worse. The bottom line is it is really is unwise to try to use an ABC powder extinguisher while you're still in the car. The powder is overwhelming, disorienting, and in most situations probably more of a hazard to your safety than a benefit.
Foam System
There are several SFI approved foaming suppression systems...and since they pass the 17.1 test you can trust that they will do their primary job: giving you time to get out of the car, and secondarily, hopefully stifling the fire sufficiently to allow the fire crew to get there. The distinct shortcoming of a foaming system has already been discussed by many of you-the coverage is not omnidirectional. It simply doesnt propagate like a gas; foam can't be relied on to get in the many hard-to-reach places in a car. The other two concerns are logistical: foam is corrosive...so there is appreciable cleanup necessary to prevent the foam from damaging your car, including the metal itself. In fact, the reason foam systems must be sent back for certification every 2 or so years is to ensure that the coating is preventing a corrosive reaction in the cylinder. The second issue is that foam is a surfactant; it's slippery. Foam on the track has been claimed to be a slipping hazard to the cleanup crew, and a difficult to clean up from the track surface. Whether or not your system wets the track is conjecture, but it is something to know in the decision process.
Gas System
The gas systems mentioned from 3M and DuPont are also on the SFI approved list; but have the reputation that the gases are suffocating. In essence yes, it is not sustainable to breathe the stuff; flourocarbons are bad for you. And I can't tell you from first hand experience what the sensation is to inhale these gases. However, the important takeaway that the suppliers emphasize is that the suppression gases are not replacing 100% of atmospheric air in the car with suppressant. The concentration of a 5lb or 10lb system fully discharged in the cabin is between 10% and 12%, which is all that is necessary to snuff the fire. The design concentration of the system is such that the occupants can remain alert and functional. The SFI criteria takes into account LOAEL levels, so you can expect that the system isn’t going to knock you out. You can see in the video above a validation of this, as the person walks in and out of the test room seemingly unfazed by the room full of the stuff he's breathing.
The design discharge rate of fire suppression systems is targeted between 0.25 and 0.5 lbs per second, which equates to 10 to 20 seconds depending on the number of nozzles used. Until learning of this, I had assumed that supression systems were an instantaneous "dump" of the tank. Also, another debunked misconception is that a 10 lb system does not inject 2x as much suppressant as a 5 lb into the cabin. For reasons of complying with LOAEL levels, the 10 lb system is designed to be plumbed into the trunk area, not to double down on the amount of gas in the cabin. At this point, it is important to consider the importance of a trunk firewall, as it has important implications on the gaseous concentration of the system.
Conclusion
If there's any conclusions I've reached for myself, is that there seems to be a significant racing precedent for using a gas system. I don't plan to hotbox myself to find out for sure, but think I am reassured that the gas systems are designed to keep occupants breathing. I think the real appeal of a foaming system is that the sprayed surfaces stay "wet" which could suppress the fire for a longer time. If fire crews take a while to reach the scene, this could play out to a real advantage in minimizing carnage. However, personally I am more compelled by the lower maintenance of gas suppression systems, and the omnidirectional coverage of a gas filling the car.
I hope this was helpful! Like I said I'm not an expert at this stuff, just fearful of fires and fascinated by the history, science, and design of suppresion systems. Please contribute if you see areas where I missed or perhaps even flat out wrong.
Link to SFI approved fire suppression systems:
http://www.sfifoundation.com/current171products4.pdf
Steven
Old 08-20-2012, 09:05 AM
pw2006's Avatar
pw2006 pw2006 is offline
I bought the H3R Halguard extinguisher last weekend (HG250B). It is a clean agent (no mess) and is non-conductive, so it shouldn't harm the electrical systems. According to their marketing materials, it is used on commercial airliners as well as by airport fire fighters. But like they say, the best fire extinguisher is the one you have. This week's project is to find a good mounting spot in the vette.
Rob
69 Camaro PT project- LS3/4L70e, Budnik's, Ridetech, Speedtech, Wilwood, DSE tubs, 4 link, shortened Moser 12 bolt- in progress
Old 08-21-2012, 05:40 AM
wrp's Avatar
wrp wrp is offline
Great rundown sik68. Aqueous Film-Forming Foam (AFFF) is advertised as cleaning up with water and the answer from vendors is usually that the recert is required to keep the SFI rating which depends on the bottle being filled by someone certified, not locally by a DIY. That implies recert is a routine fire extinguisher check for pressure. I guess in a round about way it is but there wasn't a lot of information out there implying a corrosive effect, at least for us laymen. Question I have is that since the agent is stored in liquid form awaiting the introduction of the C02 to produce the foam, what are the characteristics of the agent in liquid form. Also, if it is film forming, I wonder if is really breathable.
Also it is advertised as a water soluble clean up, which when you talk to someone that has cleaned it up you find there is still some maintenance to do to get it cleaned up. Interesting to compare facts to marketing claims. I guess that makes being an educated consumer more important.
I am going to put a second system in my car which will give me 6 nozzles (3 per). Before I put it in I may plumb it in the parking lot and set it off to see how much a bottle covers, how it covers it and what the residue looks like.
Old 08-21-2012, 11:33 AM
sik68's Avatar
wrp (name?), you nailed it! It is not always so easy to decipher facts from marketing claims, as my research found the people who are willing to inform are also willing to sell. I tried my best to sift it out, but the marketers I'm sure slipped a few past me.
Steven
