Old 08-23-2012, 07:31 PM
No need for a choke on a car like this... IMHO
Old 08-23-2012, 08:26 PM
The new Ultra HP is the best carb Holley has ever made. Even my engine builder who only likes the $1000-1500 carbs from Braswell or Bob Book said it's pretty dang good out of the box and wouldn't throw it in the garbage if I brought him one.
Old 08-23-2012, 08:57 PM
Sieg's Avatar
Sieg Sieg is offline
Thanks - I typically warm the old skool think up to at least 130* before it moves so I should be able to get the tune close enough that it won't require a lot of babysitting until 130*
Thanks Dave, that's great information.
.........I didn't know you actually had an engine builder. I thought you only had a parts advisor and machining specifications specialist on retainer.
Old 08-23-2012, 09:28 PM
sik68's Avatar
sik68 sik68 is offline
I'm running a 780cfm chokeless carb on my 355 (236/242 SR) and on the street it is definitely soft below 2500 rpm, and doesn't really come into its own until 4k. I think if it were more of a driver, I would really appreciate the 650 carb on it.
I dont miss the choke one bit though like the other guys are saying. 2 pumps, fire it up, idles on its own from dead cold.
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 08-23-2012, 09:38 PM
Sieg's Avatar
Thanks Steven, great confirmations!
Old 08-23-2012, 09:43 PM
Sieg's Avatar
This Holley technical document pretty much closed the sale for me: http://www.holley.com/data/Products/...R10565rev1.pdf
That and the functional improvements made to the new Ultra HP over the HP: http://www.holley.com/0-80802HB.asp
Poor man's fuel injection!
Old 08-23-2012, 09:59 PM
I wouldn't go that far. It's a cool carb but modern fuels aren't meant for carburetors and I don't see anyway it will prevent heat soak or flooding under heavy braking. Then throw in worse gas mileage and cold performance. Back off the cam a touch and throw EZ EFI on it and be done.
