Old 07-09-2012, 11:45 AM
Jody Jody is offline
Default T-56 Mag.
I called American Powertrain they are sending me a quote for the kit. I am not sure what to do here. I looked for the items needed for the complete installation in Summit. Summit does not show the components needed, crossmember, drive shaft yolk, etc. I called Summit they are not at all schooled up on the T56 or the components. They said they only have the T56 for new cars not my 69 Camaro. I said there are only two, one is close ratio and one is a wide ratio. He said I was wrong. Not sure if I want to buy from them. It maybe more of a pain to save the 10%( I have the 10% off coupon from a car show) than what the customer service they do not have at Summit is worth, which is very poor.
Has anyone bought the T-56 trans and found all the items needed for a complete install?
69 RS/SS Camaro, Ride Tech Level 2, 427 BBC, M21 Muncie with GearVenders Overdrive, Moser 9" w/3:73 gears.
Old 07-09-2012, 12:00 PM
Sieg's Avatar
Sieg Sieg is offline
Hurst Drivelines was very good to deal with and it's their primary business unlike Summit. I bought the T56 Mag close ratio with the conversion kit for auto to manual. Had a couple issues but they were handled in a very professional and prompt manner.
McLeod adjustable throwout bearing
Hurst Blackjack shifter if not running in the forward (stock console position)
There are other T56 companies I engaged in transactions with.........save your time, energy, and money and deal with Hurst Drivelines.
Old 07-09-2012, 12:05 PM
ma73z's Avatar
ma73z ma73z is offline
I recently bought my magnum and few other parts through American and was very pleased. I've also used Hurst drivelines in the past with good luck. I'd go through one of them and you'll be covered.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 07-09-2012, 04:32 PM
Musclerodz's Avatar
We just got a complete kit from American Powertrain. No issues other than they use a Wilwood clutch master and I used a DSE bracket which uses a GM master, no biggie.
You are correct, there are only 2 trannys, the late models use a Magnum XL which is different. You will not find tranny pricing to vary more than a couple bucks no matter where you buy it, and I have priced kits from 4-6 suppliers and complete kits all have run within $200 or less difference. Get a complete kit and take any guesswork out of ordering the wrong part.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-28-2012, 02:10 PM
claust claust is offline
Learned a lot folks...appreciate much....need a little clarification....number one...will this transmisson fit without having to massage my tunnel....if so, will the shifter fit into stock 4 spped location...will this unit bolt up to my std. clutch and bellhousing setup that came with the four speed...
thanks for any insight
Old 08-28-2012, 03:14 PM
camcojb camcojb is online now
A lot of that depends on what car you have. Bellhousing is different for sure.
Old 08-28-2012, 08:06 PM
Sieg's Avatar
From my research and observation the floor/tunnel stamp consistency in these cars has to vary a fair amount in finished height from plant to plant.........or there's a lot of liars on the internet.
Old 08-30-2012, 07:15 PM
suark's Avatar
suark suark is offline
I just got my t56 magnum from Summit, I've switched plans and am now going with a big block, I mocked it all up in the car and with the stock oil pan laying right on the crossmember, the highest I can get the trans in the drive tunnel is with a 5' down angle before it hits. I have stock height bushings with a DSE subframe, the trans is hitting the tunnel right in front of seam where the firewall meets the floor pan. I guess I'll start cutting til I get to 3' down angle. I wasn't too impressed with American Powertrain, I called for a quote on the trans and the bellhousing and all the salesman did was try to talk me into buying a bunch of other parts I already have. He said he'd call me right back with a price but never did. You'd think in this economy they'd sell me what I want when I'm standing there with money in hand? I found the best deal @ Autoplicity.com, called Summit and they beat it. I had it in 3 days, done.
1968 Camaro
Build thread: https://lateral-g.net/forums/showthread.php4?t=36348
Old 08-30-2012, 08:40 PM
snappytravis's Avatar
snappytravis snappytravis is offline
I just cut my tunnel all the way from the firewall to the back edge of the shifter plate, then about 1 down on the sides, If a guy cut it real nice you may be able to put a 2" piece of strap around the edges to raise it back up, I think it's just easier to cut it all the way out and start over, good luck
Old 08-30-2012, 09:58 PM
Sieg's Avatar
I built this and the drivetrain sits at 2.5* down.
I'm using Moroso solid motor mounts and Energy urethane rear. Standard height subframe mounts.
