Old 09-02-2012, 10:53 AM
Originally Posted by Blake Foster View Post
there is a little more info to complicate you buying descision.
As my dad likes to say.... clear as mud!
Old 09-02-2012, 11:15 AM
bret's Avatar
bret bret is offline
Supporting Vendor
just goes to show that there are many ways to acheive a desired result. The key is:
[listen closely, this is important]
If you do not know exactly how to determine IF your assortment of components is compatible for not only installation but for performance...please purchase, install, and rely on one manufacturers system!
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 09-02-2012, 12:55 PM
Blake Foster's Avatar
Red face
What he said^^^^ you will find much less frustration
Blake Foster
www.speedtechperformance.com
Old 09-02-2012, 01:45 PM
Supporting Vendor
Blake,
thanks for jumping in. . .I was hoping you'd add more input. Your system is good, and people need to know that. I think it's even better with a set of Ridetech coil overs on it! (nudge, nudge, wink, wink!)
I was only trying to state to the masses that you will typically get the best performance from a "system" designed by a single manufacturer. (now that I re-read my post I guess I didn't say it exactly).
The one thing that always gets me is people don't understand motion ratio. The front suspension moves the wheel and tire 5". This, however, does not mean the shock moves 5". Since it's located on the lower control arm between two pivoting points it moves only about half as much as the wheel/tire. So a 3" stroke could provide 6", and a 5" stroke could provide 10". However, the bumpstops only allow 5" of total travel. So "travel wise" both shocks accomplish the exact same thing. The only difference being one uses a stud mount and one uses a ring mount.
Skunk Werks
Ridetech
www.ridetech.com
