Old 08-30-2012, 11:40 PM
Macbuick's Avatar
Macbuick Macbuick is offline
Really cool build! You're doing a great job.
Thanks, I do my best , I would like to do the same works as the famous builders/shops we see on this forum, but I don't have the same budget and tooling...
You did a great job as well on your car !
I have OZ wheels from a BMW on my El Camino, they fit nicely...
[SIGPIC][/SIGPIC]
72 Skylark & 68 Pontiac Catalina+ 71 El Camino
Old 08-30-2012, 11:42 PM
Macbuick's Avatar
Originally Posted by gearheads78 View Post
Great looking build!
Thanks,
It makes me happy to have some congratulations, as building a car oversea is not easy as a local build....
[SIGPIC][/SIGPIC]
Old 09-08-2012, 07:40 AM
Macbuick's Avatar
the air funnel is in place of the headlight
The air filter will move behind the funnel to avoid the heat of the header....
I cut a plate and drill two holes to receive the shift lights
I modified an old ashtray door to accept the air/fuel monitor
[SIGPIC][/SIGPIC]
Old 09-08-2012, 07:45 AM
Macbuick's Avatar
Misalignement problem with my PYPES X pipe and the rest of the Flowmaster exhaust system... I need to order some "S" bend pipes to raise the mufflers to the right level....
[SIGPIC][/SIGPIC]
Old 09-08-2012, 05:53 PM
Lowfast's Avatar
Lowfast Lowfast is offline
Just a thought, have you considered re-clocking the blower to have the discharge point down and then route it forward under the blower? I don't know if you have room but it would make for a cleaner looking install.
1965 Ford Falcon Hardtop - PT Build
TCI Supension | Team III Wheels | Ford 3v 4.6 & TR3650
Old 09-09-2012, 12:20 AM
Macbuick's Avatar
There is no "off the shelf" blower kit for Buick engines like for Chevys, this positionning is the more easy to install and there is no room under it (steering box).
It is the same routing as many kits and making it more clean is useless as the rest is not so clean
Anyway, thanks for the idea....
[SIGPIC][/SIGPIC]
Old 10-27-2012, 08:27 AM
Macbuick's Avatar
first drive with the procharger installed.....
Still issues with charging and tuning of the carb.....too rich ! smells like hell !
https://www.youtube.com/watch?v=iYi6pRlmbNA&feature=plcp
[SIGPIC][/SIGPIC]
Old 10-27-2012, 08:34 AM
FETorino's Avatar
FETorino FETorino is offline
Congratulations that is a big milestone
Rob in SoCal
Old 10-27-2012, 08:38 AM
Macbuick's Avatar
[SIGPIC][/SIGPIC]
Old 10-27-2012, 08:41 AM
Macbuick's Avatar
thanks !
https://www.youtube.com/watch?v=n6_iO...re=context-cha
[SIGPIC][/SIGPIC]
