Old 09-27-2012, 11:11 AM
My biggest helper in "the shed" --- I'm too stupid to think complicated.
Old 09-27-2012, 11:28 AM
ccracin's Avatar
ccracin ccracin is offline
^^^^^^^^^ That is hysterical!
I've made all the same mistakes!
You don't think I'm creative enough to make that stuff up do you?
"SS" Simple Stupid
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-27-2012, 01:51 PM
MaxHarvard's Avatar
SpeedTech also sells something similar.
Old 09-27-2012, 07:06 PM
let me know, I have them for 1 1/2" and 1 5/8" tube. Two piece with hardware is $46 shipped.
Old 09-27-2012, 11:39 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Default how about this set up from Chassisworks
Did you see this set up, a bit different, but does the same thing, called a Gemini connector. I spoke to Mike at Chassisworks when I bought my G-link rear end set up and they sell just the lower machined part. Requires welding the base to the frame.
http://www.cachassisworks.com/p-1633...ild-steel.aspx
I clipped these photos from the installation instructions.
http://www.cachassisworks.com/Attach.../917055-F1.pdf
DETONATOR - 69 Camaro RS
