Old 09-23-2012, 03:36 PM
tazzz2_ca's Avatar
tazzz2_ca tazzz2_ca is offline
Excellent work and great ingenuity as always bud....
-73TA WarPath (Summer 2016)
-72RS Il Vagabondo
-70 Blue Formula "Project Cochise"
-70 Z shell
-70 Formula shell
-70 Formula roller
-68 Eldorado
-67 Coupe De Ville convertible
Old 09-23-2012, 05:41 PM
coolwelder62's Avatar
Thank's Albert,Between you and brandon I have to sneak out out midnight to find the time.
Old 09-23-2012, 06:50 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Well thought out and excellent execution! No surprise though coming from you!!
Brent
Old 09-23-2012, 06:52 PM
Thank's Brent.I wish I could go to sleep!!!!!
Old 09-29-2012, 04:58 AM
dave96dcm dave96dcm is offline
Originally Posted by coolwelder62 View Post
Who makes that sway bar bushing mount? I don't recognize the logo, is it hotchkis?
Old 09-29-2012, 07:09 AM
Those are hotchkis items.Around $125.00 pr.Stronger,an Look way better than stamped steel pcs.Plus last year I had a chance to meet John Hotchkis super cool dude.
Old 09-29-2012, 07:15 AM
Tonight I spent some time and fabbed a Accusump mount using my new Tru-Oval punchs from Holohan's Hot Rod shop.I run out of time to get it DA'd smooth.Dinner time.
When I have odd shaped pieces like this with lots of sharp edges etc --- I run 'em thru the bead blaster... with the right grit - it will take out scratches and dulls the sharps right off there!
Then the part is ready for some etching primer...
Old 09-29-2012, 07:25 AM
Greg,I was going to DA them first then glass bead them.I built this part over lunch the other day.I told Dan Holohan I would do something real quick to show his tru-oval punch's.Hoping to get some time over the next few month's to finish up and prep everything before it go's off to paint and powder coat.
Old 09-29-2012, 07:58 PM
OK, I gotta know how the sway bar in the rear adjusts? I know by moving the end link but does it get tighter by having the end link back closer to the bar and looser as it moves away? The reason it works this way is because the bar can't twist as much with the end link closer in? Am I close?
Old 09-29-2012, 08:53 PM
The longer the side arm the more leverage it has to twist the sway bar(That makes for a softer bar) .The shorter the arm the less leverage it has.(That makes for stiffer bar).The more ajustable the car is the easier it is to sort out.Soft rear bar tight car.Stiff rear bar loose car.So you are right.
