Old 10-02-2012, 11:40 AM
Moparigno Moparigno is offline
Default C6 splindle ball joint
Hello,
I'm building a custom set of control arms using the OEM Z06 spindles and hubs.
Upper arm ball joint comes with the stock spindle.
I would need to find a good ball joint ( + sleeve ) to fabricate the lower arms.
Any help on what style of ball joint (bolt-in, press-in, screw-in) to use and where to buy good stuff ?
thanks.
Paolo.
Paolo from Italy:
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383
'65 Shelby Cobra 427 Replica
Old 10-02-2012, 12:04 PM
Ron in SoCal's Avatar
Hey Paolo,
Not sure how far you want to go with this, but Howe makes a racing lower BJ for the C6 spindle:
http://www.pfadtracing.com/catalog/p...roducts_id/129
You could also call Howe directly and ask for a factory replacement.
Ron in SoCal
69 Camaro in progress
Old 10-02-2012, 12:16 PM
Hey Paolo,
So that Pfadt is a rebranded Howe?
Old 10-02-2012, 01:12 PM
Yes. Pfadt rebrands the part, but as you'd imagine Howe does the manufcturing in bulk and sells the lot to Pfadt.
You know me Dave-O, I asked Howe to sell it to me and that was a no-go. Makes sense.
Ron in SoCal
Old 10-02-2012, 01:14 PM
Hey Paolo,
thanks Ron,
so far my search ended up with Moog K6537 - it should be the correct factory replacement
Paolo from Italy:
Old 10-02-2012, 01:16 PM
I can't verify the PN for you, but was told Moog is the factory part
Ron in SoCal
Old 10-02-2012, 02:28 PM
68protouring454's Avatar
machine a steel sleeve that will accept the moog or pfadt/howe ball joint, done...
Jake's Rod Shop
Old 10-02-2012, 02:30 PM
Jake, don't be a stranger around here.
Old 10-02-2012, 11:48 PM
I never did it before. So I guessed that spending few bucks to purchase a sleeve will worth the hassle..
what is the rule of thumb for a press in ball join ? I mean, what tickness I have to consider as acceptable interference surface ?
Paolo from Italy:
Old 10-13-2012, 11:37 AM
David Pozzi's Avatar
Since the Corvette spindle is Aluminum it is thicker than a steel spindle in the tapered socket. I would stick with a C5 or C6 ball joint, others would probably be too short in the taper. The upper a arm socket is .790" deep.
Corvette lower ball joint hole in lower A arm is 1.045" thick. I don't have a stock Corvette spindle to measure the lower ball joint socket depth but I do have the LG Racing billet spindle which is 1.525"
http://www.PozziRacing.com
