Time for a brake components update!
The new gStreet billet aluminum spindle is available with 14” and 15” rotors! Think about that for a second. The 15” rotor might have a larger diameter than your car’s factory wheel. For size comparison we grabbed a large pizza box and tried to fit the rotor inside. No dice -the rotor is bigger. The new gStreet billet upright not only has a larger unit-type bearing and a trick bump-steer adjuster; it has massive brakes!
In addition to the new rotors we’ve added additional caliper options. You can now get Wilwood’s W6A six piston caliper in a nickel finish with ThermLock pistons and three different pad compounds. ThermLock blocks heat transfer from the pads into the pistons and significantly reduces the temperature of the fluid and caliper seals.
Also, we now offer a Baer caliper option- the 6S caliper. It’s available in black, red or silver and will work with the 14” or 15” rotor.
For more in depth detail,
CLICK HERE to download the product data sheet.
CLICK HERE for a brief overview of all the new components released so far.
