Old 10-04-2012, 11:27 PM
intocarss's Avatar
Complete nonsense.... fire it off and bring it up to to speed... double check the timing and set as required... If there's something not right - you'll hear it in how the motor is performing. And if there's something wrong with it - not hearing it isn't going to fix what's "wrong". It's a do over if you start hearing stuff.
Don't just set it at 2000 rpms though - vary the rpms - your neighbors are going to love you!
Go into any dyno room - you'll see the operators wearing headgear... and they're noisy as hell - you can still hear a lifter ticking if ones gone bad and you can hear the off note.
Yeah --- I'll bet I've been to 30 "run in's" and more than that - dyno runs... chassis and motors... and it's always been the same -- do your absolute best to set timing etc BEFORE fire up -- fire 'em off -- check the timing and start wingin' 'em to the moon.... The rings these days are lapped in by the time they've got all the pistons installed.... the bearings are all coated with break in lube... you've got break in oil with the right zinc and blah blah... So it's really just the cam/lifter that needs to seat... and that gets lubed by splash - thus the RPM's...
BTW -- this is ANOTHER reason we all love ROLLER CAMS!
The last two motors I've done --- the LS2 in Ricks '55 and the blown stroker in Rudy's were both fire 'em up and they idle... and you've got all the time in the world to check stuff out without the raucous rpms. With the LS"x" motors --- there isn't even anything to check out!! OMG - just twist the key and drive away!
O'L GW IS 110% CORRECT on both posts,, we never wore head gear in our dyno room though, our dyno ran through mufflers and we could hear if something is a miss. I/we first pre oil it then would fire eng, look for leaks, set and check timing, adj carb if needed..... break in cam (if not a roller) Then let her rip
I like to vary my RPM's when breaking in a cam between 1800 -2300 for about 20-25 mins and remember to check your valve lash before and after the break in. Good luck, have fun and have Rev take some video please
They have these things nowadays called telephones.
I agree with you... but all anyone wants to do now a days is text
Old 10-05-2012, 07:58 AM
Sieg's Avatar
Sieg Sieg is offline
Thanks for the info Jerry.
Old 10-07-2012, 10:49 PM
intocarss's Avatar
Old 10-08-2012, 08:00 AM
Sieg's Avatar
Old 10-09-2012, 07:26 PM
intocarss's Avatar
U tease
Old 10-09-2012, 07:31 PM
Yeah!
We need Skippers to post up that "yeah" video again....
Old 10-09-2012, 10:30 PM
Sieg's Avatar
Well.............we might have the car home tomorrow evening and parts may arrive from Summit on the 10th or 11th and I may have time to get everything done this weekend so I can light it up for the twenty minute break in period and send it back to the shop for sheet metal installation.
Old 10-10-2012, 12:15 PM
Excuses....excuses.....
Old 10-10-2012, 05:11 PM
Sieg's Avatar
Maybe tonight, maybe not...........
It's getting closer.
And no that's not where the coil is being mounted.
Last minute update! Todd just called and he's delivering the car in about an hour.
Old 10-10-2012, 08:07 PM
intocarss's Avatar
Alright I'll cut you some slack for now. I like where you have the coil mounted I also think the yellow VC's look great
