Old 10-12-2012, 12:24 PM
mdprovee's Avatar
mdprovee mdprovee is offline
Default Testing A/C
My vintage air is blowing hot air, so I have a leak somewhere. I need to test it, and find the leak so I can have A/C next year.
Is there an easy way of testing, or kits to use, that I can do at home? Are they any good? Would I be better off taking to a shop?
Any ideas?
Mike
Old 10-12-2012, 12:47 PM
Dye and a black light is best for small leaks.
Old 10-12-2012, 11:25 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
What Todd said. I will add that many times, if the components are really clean and dry you can sometimes find the leak by just looking for oily residue which usually has dirt/dust stuck to it too. So, just take a close look all over before you get the dye and black light going which will also require it to be charged up and ran for a while to show up.
Erik
69 Camaro
Old 10-12-2012, 11:36 PM
Yeah get it dyed,
PAG oil is very light and hard to see...most shops will do it for free if they do the repair.....I bet its that little vintage air plate up in the cowl. I just bet ya.
Old 10-13-2012, 07:28 AM
mdprovee's Avatar
Thanks guys, I will try the visual first, then the dye. And Vince I know it is not that plate, because the guy that made the plate is way to good.
Mike
Old 10-13-2012, 10:32 AM
LOL I was just teezin, I'd hate to try to stick head up in there.
The also make an electronicalistic detector with a wand but it has to be a pretty large leak to find it.
Old 10-13-2012, 05:59 PM
mdprovee's Avatar
Actually Vince, I want to replace my inner fenders with the Anvil ones to make more room for wider tires. I figure that will be the best time to check that location.
Mike
Old 10-13-2012, 11:08 PM
well there you go, easy peezy..... making more room for that 285 on a 18x10 6 7/8" bs rim aren't you.
when your ready swing by the shop and we'll nail that back space for you.
