Old 09-06-2012, 04:28 PM
snappytravis's Avatar
snappytravis snappytravis is offline
Default Holley Efi or Gm Performance parts
Just curious what you guys are running for engine management, I have 416 ls3 in 69 camaro and will be close to doing some wiring in the next few months I need pretty much everything. Car body, interior, headlights, taillights. I would imagine American Auto Wire. I however am confused on the engine. I see you can purchase the gm setup with pedal, o2 sensors and harness for around 1100.00. It would have to be tuned. I also was looking at the holley setup that is self tuning. What are the pros and cons of these two setups? Thanks
Old 09-06-2012, 05:26 PM
gnx7's Avatar
gnx7 gnx7 is offline
My buddy runs the Holley HP EFI on a built n/a 440ci resleeved LS2 with T56. It literally fired right up once you enter in the parameters... and it kept learning/fine tuning the more you drive it.
He has paid a few tuners in our area thousands and thousands of dollars to tune it running HP Tuners and the stock GM PCM/ECU over time with its never ending upgrades.... well it runs the best with the Holley and has made the most power (only a few more HP)... but now it also gets better fuel economy.
No more tuners wanting $400+ to tune your car... or a couple hundred if you make small changes.
I'm putting one on my 5.3 turbo setup.
Old 09-06-2012, 09:57 PM
Yes, I spoke with one vendor and he was pushing gm, Of course then he can tune it, I live in the middle of no where so if I was to take it to a tuner it would be minimun of 5 hr drive. thanks for the advice
Old 09-06-2012, 10:18 PM
If you want to learn to tune it yourself its just gonna be time, money and experience. I'd go with the Holley system.
BTW Trav, where is your build thread? I see smigets of project pictures but we wanna see the good stuff man.
Old 10-13-2012, 06:57 PM
68sixspeed's Avatar
68sixspeed 68sixspeed is offline
mine is running on the GMPP setup, very easy install with that setup and it came with the O2's, pedal, MAF sensor etc. I had a baseline tune done by a pro with EFI Live and then did some followup tweaking myself using HP Tuners. It seems to work pretty good and most tuners are familiar with either HP Tuners or EFI Live and tuning LS motors. What I'm saying is there is a wider support base for the factory based tuning where it might be harder to get help or support using the aftermarket Holley or similar controllers. 5 years from now if my computer dies I can just get another E67 and reflash it. Also any generic code-reader works on it as well as the iphone data logging apps that use the OBD-II port.
68 Camaro RS/SS, Katech tweaked LS7/t56 magnum
68 Camaro RS Convertible Project
2006 Corvette Z06
2011 Corvette grand sport convertible
Old 10-22-2012, 12:32 PM
ryeguy2006a ryeguy2006a is offline
I have heard good things about Holley EFI. Plus it has a built in wideband, where as if you wanted to utilize the Stock GMPP ecu, you would need to buy a wideband separate.
http://i105.photobucket.com/albums/m...a/Untitled.jpg
1976 Trans Am 400 4 Speed, C5 Brakes, 17" Aluminum Rims, and many more...
My Build: http://transamcountry.com/community/...?topic=24465.0
My Feedback: http://transamcountry.com/community/...?topic=37555.0
Old 10-25-2012, 06:26 PM
gray86hatch gray86hatch is offline
I have two cars running the holley efi
Dad chevelle is driven daily used the closed loop to handle the fuel map. Gets mid 20's on the highway and 17 in town. spent more time messing with the start up than anything. 6000 miles no issues
My car I put less than 10 miles on the street with 1 pull to 6000 and made my first pass with the car the map was within 2% of commanded afr.
Tuning at the track is very simple car responds is very predictable.
Tech help is only a email away and avalible after hours.
All the guys at Holley put alot of effort into what they are building.
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
Old 11-15-2012, 05:40 PM
gnx7's Avatar
V2 of the the Holley EFI is out and you can download the new features on to your older unit as of 11/12/2012.
Some highlights are boost controller and traction control modules!
Old 11-15-2012, 08:08 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Actually, when my LS3 418 with Harrop TVS 2300 was tuned, Rich Gala came down from Detroit to tune mine. My engine was sitting on the dyno, so Kurt Urban helped me out and gave me a good tuner. Cost was rather inexpensive.
Anyway, the problem with the aftermarket industry is a company can be bought out rather quick, but sticking with stock ECU then you don't have to worry about that as much. On a buy out, then those products could seize to exist.
Old 11-17-2012, 04:05 PM
PTAddict PTAddict is offline
Some observations:
The LSx-compatible Holley kits are the HP and Dominator kits, which are not of the "self-tuning" variety. This is, IMO, probably a good thing. The only self-tuning kits we've used - the FAST EZ-EFI - have yielded lousy results for us, other observations on this forum notwithstanding.
Both the Holley and Factory ECUs support knock sensing/retard, which I consider almost a must-have when tuning LSx motors for max performance - they have such efficient combustion that even a few degrees too much spark can push you well into knock and destroy an engine fairly quickly.
Factory ECU uses a MAF, which is an extra consideration when designing air intake. Factory ECU requires either HP Tuners or EFI Live software/interface to tune, which is quite expensive to acquire if you want to do your own tuning. Also, Factory ECU tuning is significantly more complicated in some areas than the aftermarket systems. But they are pretty much "plug and play" to get up and going.
The Holley systems offer more configuration flexibility, and more control inputs and advanced options as noted above, but there is a little more initial setup required as a result. They use wide band closed loop instead of MAF to control WOT fueling, a more expensive but more precise strategy. The tuning software and parameters are simpler to learn and use.
It seems like either of these can work just fine for your application, but either absolutely must be tuned in order to work well with your custom application. So the choice might come down to which system you feel more comfortable getting installed and tuned, either by you or by your chosen expert.
