Old 11-13-2012, 08:22 PM
daemon2's Avatar
daemon2 daemon2 is offline
two turbo's, I have a few diagrams of the front accessory drives to measure it out to see what will fit; thanks for the tip on the fbody setup!
and yes I will be running the f-body oil pan.
I have some other work to do on the engine, more pics when I can.
Originally Posted by krptonite View Post
that will be tight with turbos! twin or single? i think you need the fbody set up as that puts the alternater down low and the ac is low on pass side, are you running the f body oilpan too?
Daemon2
