Old 12-04-2012, 06:26 PM
transam's Avatar
transam transam is offline
Originally Posted by Rybar View Post
Paul there's a lot of Burger joints en route from here south to Cali.
I've made the trip many times, and probably more bathrooms in between
Old 12-04-2012, 07:04 PM
Originally Posted by transam View Post
I'm not sure if its a 2/3 bar, I'd assume it would have to be 2 bar for turn key to use it on a supercharged set up? And no I dont have the cable/dongle. Now you guys have me thinking,if they made a mistake and put a 1 bar map what would be a symptom ? It feels like its hitting a rev limiter when it gets Into load around 2000rpm
what does your map table go up to?
Old 12-04-2012, 08:41 PM
transam's Avatar
I don't have the cable/software to be able to see what the tune is like
Old 12-05-2012, 12:06 AM
I would not be out loading a supercharged engine with a tune I can't see or know nothing about.
Old 12-05-2012, 07:53 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Would you also maybe describe the problem as a "stumble?" The was a similar problem on an El Camino at Best of Show with a supercharged 402 from Turnkey, but it has since been resolved after a trip to Westech. Actually, the last three or so cars to go through BOS, including my own, all had a similar issue where the car had low rpm tuning issues. If you can find someone to work with the system it is probably a simple fix.
You could also tear out the computer if there is no one near you that can tune it...
Old 12-05-2012, 08:44 AM
supremeefi supremeefi is offline
Originally Posted by parsonsj View Post
I don't know about 2 or 3 bar MAPs, but the MEFI 4b and 5 are big advances over previous MEFI systems, and even those have more capability than aftermarket systems.
You keep saying that yet no one seems to know if it'll go past a 2 bar map even, it won't do sequential right? It doesn't have a lean alarm, does it have a scaleable map? I could go on and on.
If you would please enlighten us as to how it's better/more capable than the best aftermarket systems today.
I'm with Jody on this one. You have all this time and money in a boosted application. Use something that will protect your investment.
Mark
Engine builder and tuner.
Old 12-05-2012, 08:45 AM
transam's Avatar
I've done worse, but it won't even rev past 2000. You can't even give a 1/4 throttle on the car. I pulled the plugs to see that it wasn't too lean.
Old 12-05-2012, 08:55 AM
transam's Avatar
I would describe it as a rev limiter. I sent the ECM to turnkey. They claimed it had a permanent 2000 rpm limiter in it,apparently back then they didn't have a time lock break in,they expected you to bring the car back to them and they could look the engine over and then remove the lock. So I was told the lock was removed but the car does the exact same thing. So my suspicion is the lock was never removed. I'm debating if I should try sending it back to them. I will contact westech to see what is their take on it.
Old 02-13-2013, 04:40 PM
transam's Avatar
So i sent the ecm back to turnkey and they confirmed the rpm lock was removed. So i bought a codemate and ran a scan, im getting a code 41 and a code 81. Is there anything obvious i should check for or start to look at? All cylinders do fire as each primary gets hot as soon as the cars started.
"The code, 81 I am suspecting a cam/crank sensor issue or possibly injector driver problem. The code 41 correlates to the cam/crank issue, which would indicate a bad coil or misfire. A little further investigation on exhaust temps. will tell us more. This is a very strange problem"
Old 02-13-2013, 05:58 PM
Do it right and toss that system and get someone to tune the FAST XFI or similar... You've heard from the best/brightest on here... and for the most part they've suggested you get a more tuner friendly system given that you don't have the USB dongle and cable etc... and you don't have the WB O2 sensors...
Or -- ship the car to Mike -- it's not that expensive compared to the cost of rebuilding your motor...
Just saying -- after reading the thread from the beginning -- you're not getting anywhere going about it the way you are. Summer is coming....
