Old 12-11-2012, 11:04 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
I have 18 x 8 with 5.75 back spacing with a 24.5" tall front tire and it hugs the inner wheel lip very tight.
The only problem I had was the front end was still a little high so I added drop spindles to get the top of the tire even with the wheel well arch. In doing so the rim hit the outer Tie Rod. In order for it to work I install a set of Bear Tracker Hiem Joint tie rod ends and a 1/4 spacer.
If you go with Stock Spindles you will not have a problem. I was recently told that CPP makes a drop spindle that will clear a 9" rim. But I have not confirmed that yet.
First off, I have been following your Gen II build for a while now. I love the car but hate the fact that you have convinced me that I must have a tiger cage LOL.
As I sit right now Im going with the following:
2'' Drop spindles, CAC bump steer linkage, CAC upper/lower's (Anvil wheel wells if need be)
Front:18x9 5.25/5.5bs 265/35/18
Rear:18x12 5.5bs 335/30/18 57'' flange to flange housing
Opinion?
Thanks for the response
