Old 12-31-2012, 01:40 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by Matt.A View Post
How much power is that SB2 going to make again?
Todd, I'm not really a video person, but Chad at Bangshift is, and was interested in doing a write up of the "real" intake manifold when it eventually goes on. When that happens is largely dependent on Daves dyno numbers, or Rob's chassis dyno numbers.
No video? Hmm sounds suspicios.
They are all apples to oranges unless run on the same Dyno by the same operator.
Best to just sort this out at the track
Rob in SoCal
Old 12-31-2012, 02:33 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Suspiscious because you're not used to engines making That much power? Wait! I know you're actually suspiscious because you're not used to small block CHEVYS making that much power.
Old 12-31-2012, 06:49 PM
Since final compression ratio and cam specs are possibly up in the air, I'll go with this.
Minimum 725 (I'll be disappointed with anything less)
Target 750+ (This should be doable given just the dry sump upgrade and other things staying the same)
775-800 (If things get a little wild with compression and cam)
But don't go holding me to this.
You got that straight, Buttercup.
What the latest Dave? Rich paving roads or building cars?
Just finished paving roads before Xmas. Now it's full time Camaro time for Richie.
Old 12-31-2012, 08:24 PM
intocarss's Avatar
Old 01-08-2013, 10:28 AM
intocarss's Avatar
Old 01-08-2013, 10:38 AM
fleetus macmullitz's Avatar
Nah, I think it's just that ...
Old 01-08-2013, 12:55 PM
Track Junky's Avatar
Gaetano Cosentino
Old 01-08-2013, 11:57 AM
That was good.
Sounds like a marriage counselor.
Old 12-31-2012, 07:28 PM
FETorino's Avatar
Just suspicious that THAT motor runs at all.
Is it living so close to Berkeley that makes you such an optimist ?
Happy New Year hopefully that thing fires in 2013
Rob in SoCal
Old 01-08-2013, 11:25 AM
Well?????....... We're waiting......
