01-05-2013, 01:59 PM
427ci LS2 sleeved, dry sump oil pump, engine build & install, 69 Camaro
Hey guys, I am new to this site, I posted up some back ground info in the “introductions” section yesterday. I am currently a member at LS1 Tech and I did an engine build thread there that I wanted to share here at Lat-G. I did a 427ci LS engine with LS7 heads, LS7 single plane intake, 4 barrel TB, and a dry sump oil system. The thread covers the engine build, engine install, dry sump oil pump and plumbing install, and some other stuff. I wanted to try something different using the single plane intake rather than the LS long runner intake. The goal was to build an engine with a long wide power band and good top end that would work well on the street and the track.
I worked with a local engine builder on this project. The engine was built from the ground up starting with an LS2 aluminum block from a wrecked Corvette. Working closely with the builder… I was able to do testing on the engine dyno to try out different cold air intake sets ups, test the digital control fuel system, and CTSV fuel pump. I found out a few surprises testing different cold air intake set ups! I wanted to tune the engine on the dyno exactly as it would be set up in the car. I didn’t want to have issues after install. This worked out great… since the install I have had no issues and the tune is perfect. This was a good way to go.
I swapped out my 450 HP carbureted 350ci gen 1 small bock for the new fuel injected LS engine. I documented the build and install with pictures from start to finish. The duration of the project was about 12 months. The engine was installed in the car this past August. I plan to continue the build project with a swap from the Muncie 4 speed to a T56 Magnum 6 speed (trans on order  ).
I was pointed to this site by a guy on LS1 Tech. Look forward to being a member here at Lat-G
Here is the link to the build thread at LS1 Tech:
http://ls1tech.com/forums/generation...ine-build.html
" If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
01-05-2013, 02:29 PM
Welcome sir.  Sounds like a sweet motor.  Was your motor sleeved by ERL?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
01-05-2013, 03:00 PM
This is a very nice setup!
The attention to detail is over the top.
What does the car weigh full of fluids without driver?
01-05-2013, 03:04 PM
Nice plans!
01-05-2013, 03:57 PM
Sweet build!
Signed up on LS1tech the other day so I can learn a thing or two (so far not feeling so welcome there)
you are right at home here.
01-05-2013, 06:01 PM
Thanks! My engine was sleeved by Nutter. They do quite a few 427's there.
Mario Andretti
01-05-2013, 06:08 PM
Thanks! The total weight of the car with no driver is 3,420 LB. Weight distribution is 53% front... 47% rear. The aluminum block on the LS engine helped to take some weight off the front of the car.
Mario Andretti
01-05-2013, 06:11 PM
That is a bad mother trucker right there.
01-05-2013, 06:14 PM
Originally Posted by KPC67
Sweet build!
Thanks! Yea I hear you... I was also hoping to get more technical feedback on LS1 Tech. Glad to be here now.
Mario Andretti
01-05-2013, 06:21 PM
Thanks.... Yea it keeps my attention
Mario Andretti
