Old 01-25-2013, 06:06 PM
John510's Avatar
John510 John510 is offline
Default How to put lift in standard garage
How are you guys installing lifts in your standard 2 car garages?
I have a roll up garage door and it seems like once it rolls up it would hit the lift/car. Is it possible to add a lift in my garage? Any pics on what you guys have done? Thanks
[SIGPIC][/SIGPIC]
Old 01-25-2013, 07:39 PM
Saw this video somewhere recently. Build the lift into the ground.
Bad ass P car too.
http://vimeo.com/57909173#
Old 01-25-2013, 07:59 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
This is probably what you are looking for in a lift. There is a lift at neighbor's house that is in standard garage. Not sure if it is the same brand, but this give you the idea. http://www.radliftsbygemini.com/product-sg7000.php
Old 01-25-2013, 08:16 PM
John510's Avatar
Thanks. I wonder if there's one with an open bottom so I can work under my car.
[SIGPIC][/SIGPIC]
Old 01-25-2013, 08:29 PM
camcojb camcojb is online now
those center trays come out. How tall is your ceiling and door?
Old 01-25-2013, 08:58 PM
scherp69's Avatar
scherp69 scherp69 is offline
John...here's one that you can take down and put away when you're not using. Haven't seen it myself, but it looks like decent reviews.
http://www.costco.com/Dannmar-MaxJax....11589445.html
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 01-25-2013, 11:03 PM
John510's Avatar
Ceiling is 9 ft. Not sure on the garage door height. Its a standard roll up garage door with electric opener. I wanted something I could fit 1 car on top and another on the bottom but not sure if my ceiling is tall enough..
Scherp that lift looks cool but cant get another car underneath it.
[SIGPIC][/SIGPIC]
Old 01-25-2013, 11:44 PM
I don't see how you'll get a car under that lift with one on top, unless they're very short. Then you'd need to have the door up to get a car in/out of the garage, and that would probably reduce another foot or so in clearance.
I just measured mine; with the lift all the way down the top of the rails where the car sits are 4" off the ground. The 69 Camaro in the shop is 51" tall, and 55" on the lift. That means if the second car was that low also, you'd only have an inch or two clearance total for the roof to ceiling on the upper car and the roof to lift on the lower car. If you have any overhead fluorescents that makes it not fit.
And that's without the door being open.
Old 01-26-2013, 01:17 AM
yeah, thats not going to be enough, but if your garage is deep you can put the lift towards the back so you can get the front of the car under the car on the rack in up to the back of the hood.
Old 01-26-2013, 08:51 AM
aany001's Avatar
aany001 aany001 is offline
I am also in a dilemma about a lift in my 2 car garage. My ceiling is 9ft but I have a loft above it. Im thinking of making the ceiling a cathedral style and install a 2 post in the centre of the garage.
