Old 01-20-2013, 11:50 AM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
ok since it's nice outside, I decided to switch gears and work on some sheet metal to get ready for the new front sheet metal to arrive, also have the day off tomorrow to finish up some of this stuff. I also spent the weekend fixing stuff that was already broken on a car I have yet to drive other than around the block! Water pump replaced, check. Rear seal on the transmission replaced, check. Removed Driver side head to get the flange milled to get rid of massive header leak, Check. Exhaust all mocked up and built, check.
Here's some pics of the sheetmetal work today. I had to enlarge the inner fender openings to clear the corvette a arms with the new frame design. Tomorrow, I'll do the other side.
No Shop, No Money, No Time.... No problem!
Old 01-23-2013, 02:16 PM
Optima Ulimate Street car challange qualifiers announced today! Please Please somebody sponsor me and help me get to the event at CMP with DSE! My car is so close to being ready to flog! As you guys all know it's completly home built in my massive racecar manufacturing facility (10x20) attached to my house. I just need some incentives to get it over the line (or convince my wife to let me work on it more) and a few parts. Here's the list off the top of my head that's on the car, it's not big because I made most of what I needed myself!
DSE, Yes there's DSE parts on my car
AAW, great stuff!
QA1, also great stuff
Chevrolet, gotta hope for the big money!
Ricks 1st Gen Camaro parts
MSD
Comp Cams
Hawk Brake Pads
Inline Tube
Lokar products
Speedway Motors
Summit Racing
Tires (TBD) can't run Hoosier A6's at OUSCC
Wheels, Did I mention GM AKA Chevrolet?
What I need still?
Gauges, Tires, Lubricants, Brake pads, Roll cage, Safety Equipment (Harness, Fire equip ect..)
My qualifications?
I'm the VA State Auto X champ in ESP (in my WS6) Multiple champ in ESP in my local club, I'm running HPDE3 with NASA in my WS6. I've run VIR and RA, but not CMP yet. I'm a Mechanical Engineer and I built the car entirely by myself with no shop, time or money? Does that help?
Ok, Enough of the grovoling (sp?) Here's what I did on monday my day off.
Since I had the fender off, I decided to finish up the mocked up front downbars and get it ready for the new front sheet metal.
after some welding time and more grinding time this is where I ended up.
I'm expecting a few parts I need while the car is up on the stands this week, then I'll put it on the ground and turn it around so I can do the other side to prepare for the new front sheet metal.
If the Braille Battery disqualifies me, I'll add an Optima!
Old 01-28-2013, 06:40 AM
It Ain't perfect, but it's good enough for now till I pull the front clip next winter. Cleaned up the frame too, gonna shoot some rattle can paint on it and call it a day. Also added some brake ducts in the frame that will use the frame rails for the ducting from the front end. Way more work than what it looks like in the pictures!
Old 01-28-2013, 06:54 AM
Track Junky's Avatar
Hey, does Braille sell that mount or did you make it?
Gaetano Cosentino
Old 01-28-2013, 06:59 AM
Coming along nicely! Good luck getting it ready for spring.
Old 01-28-2013, 07:05 AM
Braille sells it, they have a mount to fit each size of thier Batterys. So far this little batt has been good, lots of cold cranking on it and it's never waivered.
Old 01-28-2013, 07:09 AM
Cool, thanks......hope it lasts trying to crank 14:1.
Gaetano Cosentino
Old 01-30-2013, 03:40 PM
Todays progress, a little rattle can paint goes a long way!
Old 02-04-2013, 03:28 PM
finished up the other inner fender over the weekend
Picked up the new sheet metal today! SO nice to be able to bolt on something that I don't need to sand/fix/make/alter ect...
Old 02-04-2013, 07:40 PM
Nice job on the wheel wells.
