Old 02-09-2013, 01:32 PM
SuperSport's Avatar
SuperSport SuperSport is offline
Default Fork Adjustment
Hey guys,
I have a three part question.
First is there any suggestions to removing the plug from the block? It does not seem to budge. After almost stripping the inner square part of the plug I decided to give it a go with some channel locks. No chance either. I want to put the temp sender in the original location.
Second, I am using a hayes clutch kit in a lakewood bellhousing. I measured the 4.5" from the engine saver plate to the pivot ball and here is the play in the fork. Does this seem right?
Third, Guy at Napa sold me a rear seal. They don't look the same. Will this be o.k. before I replace the on in the trans now? Any install tips? Sealant or no?
Thanks in advance. SS.
https://www.youtube.com/watch?v=fGPc_5aS-LE
