Originally Posted by 1Bad68Cat
Rod, i'll definitely check into this. When I received the module I did take off the regulator thinking I still needed to replace it with the 4th gen regulator, but saw the adapter and reinstalled it.
Thanks again everyone for the pointers.
with the vaporworx system you need to replace the regulator with a 4th gen one AND use the adapter at the same time.
You also really need to pinch the crap out of that retainer clip so it doesn't slip off. I had the exact same issue as RocketRod did.
