Old 02-16-2013, 05:57 PM
Twin_Turbo Twin_Turbo is offline
Rad fits too...well..almost LOL. Need to cut that large bulge off the steering box so I can get a hose end on the oil cooler part and I need to cut and angle the lower rad hose connection
I wanted to install the mcleod 4th gen master and didn't feel like taking the damned pedals out again. The 4th gen stud is SMALLER than the 3rd gen. Doing searches here in the past I could have sworn it was the other way around. Also, the high pedal issue..is it caused by the location? I doubt it, the location is very similar in relation to the shaft. I had a clevis that was the right ID but it's too wide, the stud on the 3rd gen pedals is too short... frustration!! I decided to take a short cut. I removed the rod end from the aftermarket master and fabricated my own clevis. There's plenty of sideways play because of the wave washer, no play af all in the direction of the pedal. Done, this will slip right on.
I decided the C5 conversion is pretty damn hideous...well...the caliper at least. It's got too much of a production look to it, not "pro touring" at all...so, I got some C6 Grand Sport calipers without logos (Kore3) thatI'll stick on. Might as well upgrade to 14" front brakes. I'd like to keep the 2pc rotors so I'm going to see if coleman or wilwood makes a rotor that bolts to the baer hub (if anyone knows the baer hub patter, 12 boltson ??? diameter)
Never liked that the C5calipers are remanuf. cores with dents and scratches.
This is going to look soooo much better
Also bought some mac SFCs so I can start fabbing my trans mount off them when they come in.Wasgonna go with alstons but since I'm going to cut them up the macs were a better deal since they were significantly cheaper.
Got some more stuff done, I got my watts linkage installed and yippee a 4" exhaust tube clears, guess that solves the size I will run there
The sway bar wouldn't clear so I fabbed some spacers, good thing I welded the sway bar saddles to the axle, I can't get longer u clamps anywhere
Welded some standoffs to the radiator and mounted it
rear calipers, they are slightly used returns because of flaking paint (will repaint them anyway)
Rear brakes will end up something like this
Fabbing up trans mount/tq arm mount off SFCs
I will use some tube connectors like from ballistic fab or something alike to make the center section removable
